Results 1 to 11 of 11
Thread: ran out of nails
04-29-2010, 12:16 PM #1
ran out of nails
I think I'll institute a new policy of looking under the deck BEFORE walking out on the deck with four other people. Oh, don't worry. Some of the joist hangers had a nail or two.
04-29-2010, 01:34 PM #2
Re: ran out of nails
Sadly that is a fairly common condition. I run across it often.
Bruce Breedlove
www.avaloninspection.com
04-29-2010, 01:56 PM #3
04-29-2010, 02:24 PM #4
04-29-2010, 05:51 PM #5
Previous HI called this out for no bond timber or hangers, the seller says he will do the repairs himself.
A dozen hangers, 15 roofing nails, VOILA!, ready for closing.
04-30-2010, 07:55 AM #6
04-30-2010, 09:26 AM #7
15 years? I've seen those EGP nail heads rust through and off in two.
The diameter is important as it will assure that the joist is positioned securely in the hanger. If a smaller diameter nail is used then the stress may not be transferred properly from the joist to the supporting member through the hanger. Also pay attention to the proper number of nails which should be placed in the hanger...very important. The nails are also of an exact length to penetrate the joists/supporting member to provide maximum holding power.
04-30-2010, 04:50 PM #8
I thought it was due to the new pressure treated wood, not the hangers, and that in fact the hangers need to be different for pressure treated wood (e.g. triple coated or stainless--the latter of which I've never seen).
Best Practices : Framing : Pressure-Treated Wood Fasteners : HGTVPro.com
I recall a news story locally the past couple of years where the high deck collapsed because the wrong bolts were used to screw the thing into the side of the house. The pressure treated wood ate right through them.
04-30-2010, 05:58 PM #9
I prefer to use black 1 1/4" drywall screws for the joist hangers.
04-30-2010, 06:48 PM #10
I use stainless hangers and fasteners when design criteria requires it or budget allows for it. They're typically two or three times as expensive than regular.
When not using stainless, I use Grace Vycor® Deck Protector™ to isolate the joist hangers from the PT lumber. Even the triple-coated stuff can rust and I'd like my structures to last a bit.
04-30-2010, 06:51 PM #11
