Results 1 to 3 of 3
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Frank Kunselman's Avatar
    Frank Kunselman Guest
    Default Re: Construction Joint needed?
    There probably is, under the stone. The joint that's there should be caulked between the stone and the concrete.
    Martin lehman's Avatar
    Martin lehman Guest
    Having that concrete planter with soil installed against the wall w/o an air gap is going to deteriorated the wall framing. I call it all the time.
