Results 1 to 10 of 10
    Gordon Schulmeyer's Avatar
    Gordon Schulmeyer Guest
    Default Deck rail question
    What is the correct measurement between wood deck rails & the measurement for the gap between the rails & deck?
    chris mcintyre's Avatar
    chris mcintyre Guest
    Default Re: Deck rail question
    Quote Originally Posted by Gordon Schulmeyer View Post
    If by correct you mean maximum, 4"
    It's less than 4" allowed per current code. The code just says a 4" sphere should not be allowed to pass through.
    simply highlighting the critical part
    Does it count if I was thinking "less than"????
    Sep 2009
    Twin Cities, Minnesota
    Thanks for the great PDF document Brandon!
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Wasn't that you that said you must limit giving out misinformation to one post per topic You met your quota is all.
    No problem. I wish they had visual interpretations written up that covered other areas as well.
    May 2008
    Atlanta
    From Brandon's pdf (photo 17), does the following apply to deck stairways as well?
    "Open risers are permitted, provided that the opening between treads does not
    permit the passage of a 4-inch diameter (102 mm) sphere."
    Seems like this would be a problem for just about every deck with a stairway having 30" rise or more.
    Yes..
