    Pete Daly's Avatar
    Pete Daly Guest
    Default Glavanized specification
    Can anyone tell me - Does the factory applied G90 finish on a standard Simpson joist hanger comply with the current building code requirement that fasteners in contact with preservative treated wood meet the ASTM B695 Class 55 minimum standard?
    Thanks,
    Peter
    mike huntzinger's Avatar
    mike huntzinger Guest
    Default Re: Glavanized specification
    Check the Simpson Strong-tie site.
    This technical bulletin from them http://www.strongtie.com/ftp/bulletins/T-PTWOOD08-R.pdf suggests the use of G90 is not recommended with many preservatives, especially in any conditions that include moisture (i.e. not inside).
    Egbert Jager
    Diamond Home Inspection
    http://www.diamondhomeinspection.ca
    Quote Originally Posted by Pete Daly View Post
    Thanks,
    Peter
    Peter,
    Probably not. I believe that the "Z-Max" coating is, but am not completely sure. The local Simpson Rep is Mike Wright.
    By the way, we have a CREIA meeting coming up in Cotati this Wednesday, 10/6 at 6:00 and Mike just happens to be the scheduled speaker. He will be talking about seismic retrofitting of existing buildings. But, I am sure he will be able to answer your question.
    Maybe you would like to come? If so, shoot me an email and I will give you the specific information.
    Are you a local home inspector? I know many of the local inspectors and your name is not one that I recognize.
    Gunnar@FullCircleInspect.com
