Results 1 to 11 of 11
Thread: Idea what this is?
05-12-2011, 10:21 AM #1
Idea what this is?
I found a floor drain in the garage and I am assuming this is the vent for it. Other ideas what else it is connected to? House is on a slab.
Scot
05-12-2011, 04:55 PM #2
05-12-2011, 05:15 PM #3
Re: Idea what this is?
Would it be safe to assume all the houses on that street have them because they are there.
05-12-2011, 11:10 PM #4
It Would apppear to be an oil tank fill tube, but I am pretty sure it was a vent for a drain line or sewer at one time. Anyone else ever seen this?
05-13-2011, 12:33 AM #5
Never saw an oil tank filling tube used as a plumbing vent, but anything's possible. What did you see that makes you pretty sure it was a plumbing vent at one time? I would be more concerned about the possible oil tank since as everyone knows, the remediation costs for dealing with a disused underground oil tank can be huge.
05-13-2011, 06:36 AM #6
Did some more investigating and it was an old vent for the sewer's on those houses before homes were vented out the roof. It serves now as a vent for a drain in the garage floor. Strange I know, alway's something to learn in this profession.
05-13-2011, 07:42 PM #7
Could it be Radon slab vent????
05-14-2011, 09:05 PM #8
What does your nose know? Did you remove the cap and smell anything like fuel, sewer, extraterrestial beings (whatever they smell like)?
05-15-2011, 08:26 AM #9
Location suggests Water Main or Sewer Lateral cleanout for building.
Proximity to Garage vehicle door and driveway as well as hinge side of entry door suggests need for Protection (as does replacement/overlay sloppy asphaltic cover upon garage apron, foundation, entry pad/walking surface and driveway).
Check with Town or City Public Works, easements, etc. Expect identification upon survey.
Protection for:
- "Buffalo Box" older "curb stop"/shut off/keystop access for city/town water supply,
- Pre 80s sewer lateral cleanout,
- possible former wellhead cap/casing improperly abandonded.
Apparent "floating" bare ground conductor alongside founation between "mystery pipe" and entry door.
Any of which are improperly paved over with sloppy asphalt /around on the raised ranch home overtop slab, garage apron and entry stoop/pad.
Rename Photos prior to posting.
05-16-2011, 03:33 PM #10
Looks like a buried trap vent pipe with standard vented cover. Pipe looks to big in picture to be an oil fill pipe plus you would need to see a vent pipe for the buried oil tank. Asphalt around pipe makes it hard to dig up trap if needed. Remove cap and look down pipe while a sink is draining nearby if you see running water it is a waste pipe.
Bob.
05-16-2011, 07:26 PM #11
Scot: Did you ask the seller or City inspector?? let us know!
