Results 1 to 14 of 14
    Mike Anderson's Avatar
    Mike Anderson Guest
    Exclamation Foundation wall changing colors...
    Any idea why the brick and concrete block are turning the orange red color about half way up?
    See pics.
    Default Re: Foundation wall changing colors...
    Quote Originally Posted by Mike Anderson View Post
    See pics.
    Just a guess, but I will say Georgia red clay.
    Mar 2008
    Charlotte NC
    See pics.
    Rain water, that splashed the red clay on the brick, before they fixed the gutters and re-sod.
    Mike Anderson Guest
    Ok, so this could be pressure washed off no problem?
    Most likely, but have you ever tried to wash mud outta jeans?
    Mike Anderson Guest
    No, but I did try to wash a pair of sneakers after a charity mud run once. After the third unsuccessful wash they ended up in the trash.
    Sep 2009
    Twin Cities, Minnesota
    Maybe from an irrigation system?
    -Jon
    Errickson Home Inspections, LLC
    http://www.erricksonhomeinspections.com
    Most likely it has stained the brick to the point that it can not be cleaned. Stay away from pressure washing! More folks screw up their homes by pressure washing them; it can and will force water into areas that it just does not need to go.
    An acid wash and a stiff brush might get rid of some of it.
    Quote Originally Posted by Jon Errickson View Post
    That is my thought too.
    That pattern is like those caused by sprinklers. Anyone in areas with high iron content in the well water for sprinklers will recognize that.
    The water for our sprinklers here in Ormond Beach is not that bad, just eventually leaves a slight discolortion.
    The water for our sprinklers in South Florida had a chemical tank which canceled out most (but not all) of the rusting color from the water.
    I had not thought about rust stains from a sprinkler, but being from Georgia, my money is still on clay.
    See pics.
    Wet Dog rubbing against them.
    My Grandpas dog rubbing his but on a fence - YouTube
    Mike Anderson Guest
    Confidant at this point it is Georgia red clay. The yard has plenty off it. I know this because I'm currently digging a french/curtain gravity drain underneath the perimeter of the below grade crawl space. Had some standing water on the low side perimeter when I bought it.
    Also, the back yard did have a big wet chocolate lab living in it from the previous home owners...
    Not underground sprinklers are installed. Ground stays fairly saturated in the back yard.
    Healdsburg, CA
    That dog mnay have been doing more than rubbing on them?
    Na His Favorite Spot was on the other side of the yard.
