Results 1 to 9 of 9
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Fiber Cement Board Siding
    Is a clip required at the joint between the boards in the fiber cement siding. Town home built in 97
    Default Re: Fiber Cement Board Siding
    I've not heard of a clip being required.
    e.
    Nor have I but I was "informed" this may be the case.
    The ends should fall on a stud and be nailed to the stud.
    AFAIK no need for a clip.
    Hardie Say's Nail http://www.jameshardie.com/pdf/insta...eplank-hz5.pdf
    Your Mileage May vary
    Oct 2011
    Minneapolis, MN
    That's some of the ugliest siding I've seen. What's the look they were going for, poorly planed wood?
    - James Burgh, 1754.
    Apr 2008
    Western Massachusetts
    If that's Hardie (I recall a "Colonial Roughsawn" product they had that looked like that) then no clip is required, joints should fall on studs (nails 3/8" from edge), and butt joints should be flashed or caulked (back in '97; today they only recommend flashing of butt joints).
    This info is for Certain Teed
    10 Installation Tips
    http://www.certainteed.com/resources...Tips_FC037.pdf
    Note item 8 and 9
    Installation Instructions
    http://www.certainteed.com/resources/fc017.pdf
    Thank you.
