    Aug 2010
    BC Canada
    Default what is this assembly?
    This is 1996 townhouse with underground parking. I do not know what is this on the siding.
    A damper or a security assembly?
    Thank you
    Default Re: what is this assembly?
    That is a photo cell, most likely for turning security lights on and off.
    Aug 2010
    BC Canada
    the same building, visible drain tile is cast iron which goes to underground parking. any advantages of cast iron? never seen this before.
    Only thing that comes to mind with that being cast iron is that the gutters are draining into the building sewer piping as it exits from under the building - if that is the case that is not allowed.
    Aug 2010
    BC Canada
    1996 TH, I do not think it has combined drain. probably for fire stop consideration
