Thread: Ledger Flashing
    Sep 2007
    Fredericksburg, VA
    Default Ledger Flashing
    90% of the time I'm writing up decks for no ledger board flashing. Then I ran across this yesterday. A bit of overkill especially since it was a fully covered screen porch.
    Stu, Fredericksburg VA
    Orlando, FL
    Default Re: Ledger Flashing
    But was the flashing installed correctly?
    Sep 2007
    Fredericksburg, VA
    NO. Check the pictures of the roof flashing at brick wall I'll post later. Small counter flashing over brick and mortar no step flashing under it on pitched roof.
    This was a custom built house in a high-brow development built in 2006. Not awful, but sure not what somebody thought they were getting at the time. But they did build the large masonry double wide "dummy" chimney. All for a direct vented gas log appliance to pass through, not vent up.
    Oct 2011
    Minneapolis, MN
    I'm guessing it was installed simply to shield the brick when the deck is cleaned. I looks like it's got some corrosion toward the bottom.
    - James Burgh, 1754.
    Quote Originally Posted by Kristi Silber View Post
    Yeah,
    Water Never Splashes over one or two Bricks High in a High-Brow Development.
    Sep 2009
    leonardo, new jersey
    that looks like the lime start to corrode the aluminum
    Joseph Ehrhardt
    Building Forensic Specialist LLC
