Thread: downspout drain to window well
06-07-2012, 09:43 PM #1
First time I saw this. it looks like EPDM membrane under gravel. Downspout drains to the gravel. also downspouts drain above & underground in this building. Why did they build this single one like this?
2001 detached.
06-08-2012, 03:59 AM #2
Re: downspout drain to window well
I would assume this runs down to the footing drains, along with the drain in the window well.
Randy Gordon, construction
06-08-2012, 05:18 AM #3
useing the footing drains is a bad idea and is the cause of many basement floods
06-08-2012, 07:14 AM #4
06-08-2012, 07:15 AM #5
06-08-2012, 09:28 AM #6
The downspouts should be directing the water as far away from the building as possible and I would not recommend that it go into the footing drains as they can get overloaded. Certainly into a window well area will lead to nothing good that I can think of.
06-08-2012, 01:33 PM #7
