Results 1 to 12 of 12
Thread: Flashing for balcony?
12-09-2012, 03:00 PM #1
At the front of the balcony, and in between the floor planks and over the top of the trim board, is flashing required?
12-09-2012, 03:05 PM #2
12-09-2012, 03:43 PM #3
12-09-2012, 03:43 PM #4
Re: Flashing for balcony?
I say no, too. But on my own deck, which is ten feet off the ground, I used pressure treated lumber for the rim joists. Not required but seems like common sense after having to tear off my entire deck last year because of rot in the untreated fir rim joists.
12-09-2012, 03:57 PM #5
YE-OW !!
How is the ledger board attached to the dwelling?
12-09-2012, 06:05 PM #6
The photo is actually a joist against the sidewall.
This new photo is the end of the joist against the headwall, if you will.
No ledger, and I don't believe the joists are canterlivered out; I guess they could be. I suspect the joists are just toenailed into the house somehow
12-09-2012, 06:30 PM #7
12-10-2012, 06:40 AM #8
You say that like its a bad thing?
It looks like that white strip below the planking is flashing, but is it something else? Obviously, they should have flashed the ledger board to the wall and joist to the side wall. Or flashed any blocking if they cantilevered the joists. It is nice trim work so the guys must have done the work before breaking out the brewskys.
12-10-2012, 05:09 PM #9
Would it be reasonable to comment on the stained streaks you see? I'm thinking its from rust from the flashing? Or any other ideas?
12-10-2012, 06:36 PM #10
My concern would be Catastrophic Failure after it separates from the dwelling as it is not properly attached . Austin balcony collapse sends 20 people crashing down ravine | kens5.com San Antonio
12-10-2012, 07:26 PM #11
Billy,
why do you think this would collapse?
12-10-2012, 07:40 PM #12
If the only thing holding it against the wall is what's shown ( toe nailed and misinstalled joist hangers ) and a load is applied ( such as people at a gathering ) why do you think it would not collapse ? It needs a proper ledger board lag bolted to structural members to keep it from seprating from the wall and going down to the ground .
https://www.google.com/search?q=deck...w=1024&bih=665
