Results 1 to 3 of 3
Thread: What is the proper way....
09-24-2007, 05:21 PM #1
09-25-2007, 07:06 PM #2
Re: What is the proper way....
any takers?
09-25-2007, 07:34 PM #3
Depending on how it was constructed, and from what, the best solution might be to let it drain out. I looks 'added after the stone', so if ... *IF* ... there are no fasteners through the stone, and if ... *IF* ... there is not non-pressure treated wood there to rot ... maybe just let it drain out.
To many *if*s and not enough information photos from all angles, etc., to make an informed statement about it.
Otherwise, it would entail removing the stone, installing a through the wall flashing, and more flashing, then re-installing the stone.
Do you recommend sealing at the bottom of the casement trim (3rd photo)?
Flashing required where the balcony band board interfaces this stone column? (4th photo)
