01-21-2013, 05:35 AM #1
Re-painting Corroded Steel Stairs
Anyone have links for objective sources of information WRT the best methods of re-painting corroded steel exterior stairs? I can find plenty of discussion and "advice", but none of it appears to be based on actual studies or testing of coatings/methods.
Thanks in advance.
01-21-2013, 07:11 AM #2
Re: Re-painting Corroded Steel Stairs
Don't know about stairs but you might check out website dealing with restoring old cars, there is a lot of information on how to remove & convert rust and painting.
Just a thought
Link for one site - Eastwood - Auto Body Repair Tools | MIG Welder | TIG Welder | Plasma Cutter | Auto Body Supplies & Accessories
http://www.jjeffzehnder.com/
01-21-2013, 08:20 AM #3
Try this, we used it in the Gulf on steel boats Corroseal Rust Converter | Metal Primer | Rust Paint
01-21-2013, 11:21 AM #4
You did not say rusted but used the term corroded. Depending on how far gone the metal is would determine what to use if anything but just replacing them.
Being where you are I am picturing pretty corroded steel fire escapes. It may be extremely worth having someone check them out. Looking solid may just be the immediate visual but destined to fail any day now.
01-22-2013, 03:11 AM #5
Thanks for the responses - these are the poorly originally painted steel stairs and landings frequently seen at the rear of Chicago condos built post 1990.
01-22-2013, 05:44 AM #6
