Results 1 to 16 of 16
05-09-2014, 01:00 PM #1
05-09-2014, 01:31 PM #2
Re: Dry stacked block columns and bags of mortar as foundation.
Those appear to be supplemental supports, probably to correct objectionable deflection. One persons objectionable may not be objectionable to another. They may have had a china cabinet that rattled when someone walked across the floor, they might have been very large people, don't know! The thing I look at is; if the supports were not there, would there still be a reportable problem? I would still mention they are in the crawlspace and there condition but might not recommend any action.
05-09-2014, 02:03 PM #3
Pretty much as Vern said, but a little stronger.
Mostly FYI
05-09-2014, 05:11 PM #4
05-09-2014, 05:29 PM #5
05-09-2014, 05:56 PM #6
05-09-2014, 05:59 PM #7
We see dry stacked peirs under mobile homes all the time. Works OK.
I agree, posts in pics 1 and 3 were added later.
I would describe the piers with enough pics to make it all clear, what you see is what you get.
05-10-2014, 06:01 AM #8
Mobile homes are "Well just that" Mobile structures. No need for permanent fixtures. I don't have problems with short dry stacked columns, but if the columns and girt are a permanent solution (like pic#2) then a footing at proper depth and size for location is required.
05-10-2014, 06:18 AM #9
A) "Mobile homes" are actually not just that, unless you want to think of any home as being "mobile" because they can be moved.
B) Mobile homes are actually "manufactured homes" and are installed on "permanent foundations".
A car is "mobile" ... A "mobile home" would be an RV ...
05-10-2014, 11:57 AM #10
Home is 1600 square feet, single story ranch, on block foundation. Picture #2 does show center girder (double 2 X 12). Girder is centered with 16 foot 2 x 12 floor joists (on 16" centers) running to the back and to the front foundation walls. The girder is supported with dry stacked blocks. The dry stacked blocks are sitting on concrete footers (quality unknown) and two are leaning. The bags of concrete and 6 X 6 posts are positioned between the girder and the front and back wall. Given the girder and joist material used I assumed the 6 X 6 structures to be "floor stiffeners", added by the home owner. Unfortunately the owner died recently so the exact reason is not known. I reported the column construction to be unorthodox and should be considered "temporary" supports only.
- - - Updated - - -
05-11-2014, 05:45 PM #11
Jerry, I call them manufactured homes after 1974. "Mobile" just slipped out by mistake there.
Around here the foundation is dry-stacked CMU's under the steel frame.
Preferably on a poured concrete footing. So I guess that concrete slab qualifies for permanent.
Anyway, the stack of blocks can be solidified with rebar and concrete. I would think in Tennessee they can figure out how to get buckets of concrete in there.
05-11-2014, 06:09 PM #12
05-11-2014, 06:30 PM #13
I do it occasionally myself, but ... we had just finished making reservations for our next camping trip with our motorhome ("mobile home" ) and that target was just too big to miss.
05-11-2014, 07:22 PM #14
Wheelbarrell and a hoe for the mixin', Plastic snow sled fer the haul, the haul thru the crawl. Y'all.
Hard to splash in the right amount of water if they don't even got buckets down there in Tennessee.
We get a few MH's on tippy piers, but with the wheels and axles in place, she won't roll far. []
05-11-2014, 07:30 PM #15
05-22-2014, 05:26 PM #16
