Results 1 to 12 of 12
    cory nystul's Avatar
    cory nystul Guest
    Default cement block with unknown drain of filler neck
    I was at a a house from 1941. in the back yard was a large cement block with either a filler neck or drain. Does anybody have any ideas what this might be?
    Default Re: cement block with unknown drain of filler neck
    It looks like a concrete laundry tub turned upside down and that pipe is the drain.
    Bill Chinook's Avatar
    Bill Chinook Guest
    I concur with Raymond, at first it looked like a possible underground storage tank, but it really does look like some sort of basin turned upside down.
    cory nystul Guest
    Quote Originally Posted by Bill Chinook View Post
    That's what i thought but it is HEAVY! it appears to be solid, and no spots for attaching legs.
    My second guess would be the top of a former cistern or septic/grey water tank.
    Robin Wells's Avatar
    Robin Wells Guest
    I agree.
    - - - Updated - - -
    Quote Originally Posted by cory nystul View Post
    Hmm.. although I have seen them where they sit in a type of rack with legs.. and do not actually attach to them.
    But if it is solid..
    Inverted feed trough? Oblong Cattle Trough - 350gal / 1620 ltr : Thomson Concrete and TC PAWS!, For all your plumbing, water and concrete supplies
    Correction: It is a 'concrete' object, and one of its ingredients is 'cement'.
    It is a bomb shelter for rodents. Doesn't everybody have them?
    Nampa, Idaho
    I agree, it's just an upside down concrete laundry sink sitting on the ground.
    Aug 2011
    Base for the dog's hot tub.......
    It sure looks like an upside down basin. Is it stuck/frozen to the ground?
    Mar 2012
    Lansdale, PA
    Raymond nailed this one. The drain assembly looks like thousands that I have seen. So does the shape. They usually sit on steel or cast iron legs.
    - - - Updated - - -
    - - - Updated - - -
    Mark you are repeating yourself.
    Yes do a Google search using term "concrete laundry tub" and then go to images, different stands, et ceteras.
