Results 1 to 10 of 10
04-03-2016, 05:08 PM #1
Another exam question from the NHI Exam
ok so i had this really strange question in my National Home Inspection Exam. The question was which one of these options according to the standards do we not have to inspect.
A. Roof.
B. Crawl Space or Basement (I can't remember which one)
C. Garage
D. Attic
Obviously I am a newb but I thought we had to inspect all of these so I was pretty confused by my options to answer this question. Am I missing something?
04-03-2016, 08:40 PM #2
Re: Another exam question from the NHI Exam
We need the exact wording of the question.
We do not have walk a hazardous roof or enter a hazardous crawlspace. Or it may be worded as a trick question, or none of the above.
04-03-2016, 08:43 PM #3
04-04-2016, 06:44 AM #4
04-04-2016, 06:51 AM #5
thanks guys
04-04-2016, 07:16 AM #6
ASHI SOP
Structural Systems -
3.2 The inspector is NOT required to:
C. enter under-floor crawlspace areas that have less than 24 inches of vertical clearance between components and the ground or that have an access opening smaller than 16 inches by 24 inches.
D. traverse attic load-bearing components that are concealed by insulation or by other materials.
13 GENERAL LIMITATIONS AND EXCLUSIONS
D. The inspector is NOT required to enter:
1. areas that will, in the professional judgment of the inspector, likely be dangerous to the inspector or to other persons, or to damage the property or its systems and components.
2. under-floor crawlspaces and attics that are not readily accessible.
04-04-2016, 12:50 PM #7
here's a question that was on the NAHI cri test--what is the cause of BLUE BABY SYNDROME--cvf
04-04-2016, 05:00 PM #8
04-04-2016, 05:08 PM #9
EXACTLY--all 10 inspectors i believe got it wrong--we most answered lead poisoning--but the answer is it is from nitrate contaminated ground water--and septic tanks was the answer--believe me i gave my national some **** on that stupid question--
04-04-2016, 06:56 PM #10
