Thread: Stucco
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default Stucco
    Default Re: Stucco
    The 2" clearance, no.
    The foundation weep screed along the foundation, yes.
    Proper screed along the brick, yes.
    But 2" clearance, no.
    Fuquay Varina, NC
    Lightbulb Re: Stucco
    Please put your location in your profile.
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Default Re: Stucco
    Quote Originally Posted by Warren Alderman View Post
    Jerry, why isn't 2 inch clearance needed?
    That would just expose framing, or siding, or sheathing, or something.
    You need the 2" clearance above a roof, etc., but, for a foundation, you want the stucco/metal lath/paper/paper/sheathing/foundation weep screed to extend over the foundation/wall joint.
    With the vertical side, you want the screed to be adjacent to (approximately 1/8" - 1/4" from) the brick/wood/whatever to allow for a caulk joint from the screed to the other material. The stucco is plastered up to and into the screed, leaving the 1/8" - 1/4" joint open to accept the caulk/sealant.
