Results 1 to 19 of 19
    Ken Britt's Avatar
    Ken Britt Guest
    Default Deck attached though siding...
    When inspecting a house today, I came across a deck that was bolted through the siding into the house. So, you have the deck plate, siding, then the house. I think I'm going to write it up. What do you guys think?
    Default Re: Deck attached though siding...
    Quote Originally Posted by Ken Britt View Post
    It is hard to tell from the picture. But one thing is that it has no flashing between the deck and house.
    As you are in GA, you should checkout the Gwenette County guidelines for decks. I'll try to post it later if you can not find it on Google.
    This is a great guide for decks that is from the American Wood Council. They have several fee downloads.
    American Wood Council Code Design for Code Acceptance Publications
    This is the link to the file http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
    Ken,
    For your viewing enjoyment.
    New Guides to Help Meet the Latest Code Requirements
    Ken Britt's Avatar
    Ken Britt Guest
    Thanks guys! I'll look at those links.
    Ken Britt's Avatar
    Ken Britt Guest
    I can't find anything about connecting through the siding. Just much about flashing. Oh well, I guess I'll mention it because if the deck builders just bolted through the siding then the flashing may not be adequate or even there.
    Deck Framing Connection Guide Page 7 Ledger Attachment
    Ledger may not be installed over siding or stucco. It must be fastened directly to the rim joist or stud or through sheathing into an appropriate framing member.
    Bob White's Avatar
    Bob White Guest
    Since January 1, 2002, Georgia has specified in paragraph 502.2.1 (IRC 2000 with GA amendments) that deck
    ...shall be constructed in accordance with this code or Chapter 3 of the 1996 Forest Products society, "Wood Decks, Materials, Construction, and Finishing" maunal...
    As of January 1 2007, The code went to the 2006 IRC with GA amendments --- attached.
    You're gonna see lots and lots of decks attached like the one in the photo, bolted directly through the siding (usually hardboard), with too few bolts, and no flashing whatsoever. Write'm up.
    Attached Files Attached Files
    Ken Britt's Avatar
    Ken Britt Guest
    OK. I'm writing it up. The deck was built a few years ago, but I'll mention it.
    Thanks again!
    Ken Britt's Avatar
    Ken Britt Guest
    I also need to refresh my page before posting again - sorry Billy!
    Ken,
    You missed something. Fasteners also have to get through the substrate before they hit the house framing. Is that a rotated board in the picture??
    Eric,
    That looks to be lap siding with the ledger against two high points of two boards, leaving a space behind it due to the angle of the lap siding.
    Succasunna NJ
    Coming soon....
    I don't know how many people are aware of this, but a supplement to the IRC will be out shortly (if not already) concerning deck connections.
    This will require exact location of bolts (2 inches in from edge, 2 inches from top & bottom staggered). It will also require that at least two locations, the deck joist must tie directly to the interior floor joists.
    The problem is the diagram also shows the interior sub floor being nailed 6 inches on center of the (interior) joists that are connected to the deck joists. When adding a deck, how can this be accomplished?
    Darren
    Ken Britt's Avatar
    Ken Britt Guest
    Yes, the fasteners are going through the siding into the sheathing.
    By making all added decks self-supporting and not tied to the structure?
    Seems reasonable to me - if there is no practical way to secure the deck to the structure, make it self-supporting.
    Coming soon....
    Darren
    I think that this publication has all of the new IRC stuff about decks in it
    Scott,
    Great information in there, thanks.
    Did you notice that, for free-standing decks, the deck footings must be at same elevation as existing house footing?
    Now think 'house with basement' ... uh-huh ... way down there.
    Scott,
    Wow. That seems a little over-kill, doncha think? Frost line isn't good enough?
    My copy of the 2006 IRC says, R403.1.4.1 Exceptions 3. Decks not supported by a dwelling need not be provided with footings that extend below the frost line. So they went from that to requiring a footing all the way down at the level of the house footing?
    Last edited by John Arnold; 12-06-2007 at 06:34 PM. Reason: corrected IRC reference
    Succasunna NJ
    http://www.iccsafe.org/cs/codes/2007...ent/IRC07S.pdf
    Scroll down and start at page 38
    Darren
