Results 1 to 19 of 19
Thread: Deck attached though siding...
12-05-2007, 11:28 AM #1
When inspecting a house today, I came across a deck that was bolted through the siding into the house. So, you have the deck plate, siding, then the house. I think I'm going to write it up. What do you guys think?
12-05-2007, 11:44 AM #2
Re: Deck attached though siding...
It is hard to tell from the picture. But one thing is that it has no flashing between the deck and house.
As you are in GA, you should checkout the Gwenette County guidelines for decks. I'll try to post it later if you can not find it on Google.
This is a great guide for decks that is from the American Wood Council. They have several fee downloads.
American Wood Council Code Design for Code Acceptance Publications
This is the link to the file http://www.awc.org/Publications/DCA/DCA6/DCA6.pdf
12-05-2007, 11:58 AM #3
Ken,
For your viewing enjoyment.
New Guides to Help Meet the Latest Code Requirements
12-05-2007, 12:16 PM #4
Thanks guys! I'll look at those links.
12-05-2007, 12:25 PM #5
I can't find anything about connecting through the siding. Just much about flashing. Oh well, I guess I'll mention it because if the deck builders just bolted through the siding then the flashing may not be adequate or even there.
12-05-2007, 01:00 PM #6
12-05-2007, 01:55 PM #7
Since January 1, 2002, Georgia has specified in paragraph 502.2.1 (IRC 2000 with GA amendments) that deck
...shall be constructed in accordance with this code or Chapter 3 of the 1996 Forest Products society, "Wood Decks, Materials, Construction, and Finishing" maunal...
You're gonna see lots and lots of decks attached like the one in the photo, bolted directly through the siding (usually hardboard), with too few bolts, and no flashing whatsoever. Write'm up.
12-05-2007, 01:58 PM #8
OK. I'm writing it up. The deck was built a few years ago, but I'll mention it.
Thanks again!
12-05-2007, 02:13 PM #9
I also need to refresh my page before posting again - sorry Billy!
12-05-2007, 08:05 PM #10
Ken,
You missed something. Fasteners also have to get through the substrate before they hit the house framing. Is that a rotated board in the picture??
12-05-2007, 08:10 PM #11
12-06-2007, 04:21 AM #12
Coming soon....
I don't know how many people are aware of this, but a supplement to the IRC will be out shortly (if not already) concerning deck connections.
This will require exact location of bolts (2 inches in from edge, 2 inches from top & bottom staggered). It will also require that at least two locations, the deck joist must tie directly to the interior floor joists.
The problem is the diagram also shows the interior sub floor being nailed 6 inches on center of the (interior) joists that are connected to the deck joists. When adding a deck, how can this be accomplished?
Darren
12-06-2007, 06:08 AM #13
Yes, the fasteners are going through the siding into the sheathing.
12-06-2007, 06:36 AM #14
12-06-2007, 07:37 AM #15
I think that this publication has all of the new IRC stuff about decks in it
12-06-2007, 05:29 PM #16
12-06-2007, 05:44 PM #17
12-06-2007, 06:33 PM #18
My copy of the 2006 IRC says, R403.1.4.1 Exceptions 3. Decks not supported by a dwelling need not be provided with footings that extend below the frost line. So they went from that to requiring a footing all the way down at the level of the house footing?
Last edited by John Arnold; 12-06-2007 at 06:34 PM. Reason: corrected IRC reference
12-06-2007, 07:24 PM #19
http://www.iccsafe.org/cs/codes/2007...ent/IRC07S.pdf
Scroll down and start at page 38
Darren
