Results 1 to 2 of 2
Thread: More Stucco question
04-12-2007, 12:46 PM #1
Similar Threads:Last edited by Jeff Eastman; 12-19-2007 at 03:14 PM.
04-12-2007, 03:02 PM #2
Re: More Stucco question
Depends.
Meaning, I can't tell from the photos.
*IF* the stucco was installed on all of that wall 'first', 'then' the wood trim added. probably not.
*IF* the wood trim was installed 'first', 'then' the in-fill areas between the wood trim stuccoed, it absolutely needs all kinds of things to allow for the water getting behind the stucco to drain to the outside.
