Results 1 to 13 of 13
    Apr 2010
    Reisterstown, MD
    Default Identify this item?
    Who can tell me what this item is? This is a relatively new (2001) development. Public water and sewer. Each home in this end of street circle has one by their driveway or in their front yard (11 homes).
    Bob Kenney
    www.IndependentHomeInspectionMD.com
    Call or TEXT : 410-504-3751 rkenney74@comcast.net
    Garland, TX
    Default Re: Identify this item?
    Quote Originally Posted by Bob Kenney View Post
    vent cover
    https://store.aquatechnologygroup.co...yle-tank-vent/
    were these low lying properties compared to surrounding area?
    possibly lift stations under the covers
    Oct 2010
    MONTREAL QUEBEC-CANADA
    Vent.
    Waste and road/rain water separate?
    If it is for a lift station (for sewage) there should be a red light and alarm on it which signals to everyone that the lift station is not functioning.
    Typically, the alarms are audible to the surrounding area (sometimes these audible alarms are not used - sometimes they are remote alarms which are connected to the systems monitoring station).
    The red light is typically required to let everyone know to 'lookee here, there is even a sign below my red light, it tells you who to call' ... because $hit does not flow up hill on its own - ask any plumber, they will tell you that "$hit flows down hill" (that typically includes 'from the boss down to the worker in the trench').
    Apr 2013
    High Springs, Florida
    Sewer grinder pump
    www.1stproinspection.com
    Certified Master Inspector
    Like Us On Facebook
    https://www.facebook.com/1stproinspection/
    Knoxville, TN
    In my area, the alarm (and light) is always mounted on the side of the house. I have had to call the number a few times on vacant houses. They are usually pretty fast to respond.
    Pumps/lift stations for individual houses - I've found the same as you.
    He said that it was a relatively new development with public water and sewer, which lead me to suspect that may be a lift station for surrounding houses to (such as a cul-de-sac), which would put that for the public sewer system.
    Anyways, that was my thinking.
    Oct 2010
    Reasonable thinking IMO.
    Connecticut
    you should be willing to remove those tops if you are not sure what they are. just sayin.
    Could be grinder or pump up. now your client has to hire a pro!
    I disagree about removing the cover! While I'm not afraid to check out things I have questions about, no way I am digging up the area around a 300+ lbs cover and trying to lift it to satisfy my curiosity. I'll research it. Also, it may or may not belong to the property and the owner may take umbrage to unauthorized access and I'm not messing with it without knowing more.
    Agreed.
    Jerry...The full quote is;All you need to be a Plumber is **** flows downhill, payday is on Friday and don't bite your finger nails.<grin>
    877-466-8504
    Apr 2008
    McKinney Texas
    That clearly is a dohicky, or possibly a thingahmajig, depending on the length of the shaft. I recommend hitting it with a hammer. If it cracks, then it is a whatchamaycallit, and not a dohicky as originally thought.
Tags for this Thread
