Results 1 to 13 of 13
Thread: Identify this item?
03-21-2017, 09:16 AM #1
Identify this item?
Who can tell me what this item is? This is a relatively new (2001) development. Public water and sewer. Each home in this end of street circle has one by their driveway or in their front yard (11 homes).
03-21-2017, 01:23 PM #2
Re: Identify this item?
vent cover
https://store.aquatechnologygroup.co...yle-tank-vent/
were these low lying properties compared to surrounding area?
possibly lift stations under the covers
03-21-2017, 06:15 PM #3
Vent.
Waste and road/rain water separate?
03-21-2017, 07:15 PM #4
If it is for a lift station (for sewage) there should be a red light and alarm on it which signals to everyone that the lift station is not functioning.
Typically, the alarms are audible to the surrounding area (sometimes these audible alarms are not used - sometimes they are remote alarms which are connected to the systems monitoring station).
The red light is typically required to let everyone know to 'lookee here, there is even a sign below my red light, it tells you who to call' ... because $hit does not flow up hill on its own - ask any plumber, they will tell you that "$hit flows down hill" (that typically includes 'from the boss down to the worker in the trench').
03-22-2017, 04:16 AM #5
Sewer grinder pump
www.1stproinspection.com
Certified Master Inspector
Like Us On Facebook https://www.facebook.com/1stproinspection/
03-23-2017, 09:26 AM #6
03-23-2017, 09:40 AM #7
Pumps/lift stations for individual houses - I've found the same as you.
He said that it was a relatively new development with public water and sewer, which lead me to suspect that may be a lift station for surrounding houses to (such as a cul-de-sac), which would put that for the public sewer system.
Anyways, that was my thinking.
03-23-2017, 11:30 AM #8
03-27-2017, 06:59 AM #9
you should be willing to remove those tops if you are not sure what they are. just sayin.
Could be grinder or pump up. now your client has to hire a pro!
03-29-2017, 08:22 AM #10
I disagree about removing the cover! While I'm not afraid to check out things I have questions about, no way I am digging up the area around a 300+ lbs cover and trying to lift it to satisfy my curiosity. I'll research it. Also, it may or may not belong to the property and the owner may take umbrage to unauthorized access and I'm not messing with it without knowing more.
03-29-2017, 09:55 AM #11
04-14-2017, 06:30 AM #12
04-14-2017, 10:20 AM #13
That clearly is a dohicky, or possibly a thingahmajig, depending on the length of the shaft. I recommend hitting it with a hammer. If it cracks, then it is a whatchamaycallit, and not a dohicky as originally thought.
