		Thread: Guard openings
	11-28-2018, 05:39 PM #1 Guard openings Guard openingsDoes this deck guard opening meet building standards for a 2003 built home (still going to call it out as a safety issue) Thanks In Advance
	11-29-2018, 05:25 AM #2 Re: Guard openings Re: Guard openingsLike you stated I would list it as a safety issue but in my area it is a common practice.
 http://www.jjeffzehnder.com/
	11-29-2018, 06:47 AM #3 Re: Guard openings Re: Guard openingsIn 2003 most, if not all, codes had gone to not allowing a 4" sphere to pass through, as I recall.
 Even if those were spaced 'just under 4" apart', I have never found any which could be tightened enough to nit spread out, allowing the 4" sphere to pass through.
 Typically, you can use one hand, spread your fingers, and those spread apart. If you can do that with your hand, it is highly unlikely that it could resist a 50 pound pad load applied to it ... unless you have REALLY STRONG hands in spreading fingers apart (versus "grasping").
	12-04-2018, 03:19 PM #4 Re: Guard openings Re: Guard openingsHere in Alberta, climb-ability is also a factor in not allowing those otherwise beautiful cable railings.
	12-04-2018, 04:28 PM #5 Re: Guard openings Re: Guard openings
	12-28-2018, 12:40 AM #6 Re: Guard openings
		Mazza Inspections and stuff... Re: Guard openings
 https://mazzainspections.com
 https://waterintrusionspecialist.com
	12-28-2018, 06:37 AM #7 Re: Guard openings Re: Guard openings
  Reply With Quote Originally Posted by Egbert Jager
