Results 1 to 2 of 2
    j.Peter Buss's Avatar
    j.Peter Buss Guest
    Default Are risers required at wood deck stairways
    Are risers required at wood deck stairways ? If so is this a code issue in chicago ?
    Peter Buss
    David Banks's Avatar
    David Banks Guest
    Default Re: Are risers required at wood deck stairways
    Quote Originally Posted by j.Peter Buss View Post
    Peter Buss
    Are you under IRC?
    2003 IRC. R311.5.3.3 Last sentence.
    Open risers are permitted, provided that the opening between treads does not permit the passage of a 4- inch diameter sphere.
