    Jerome W. Young's Avatar
    Jerome W. Young Guest
    Default flashing at bottom plate
    I see this often here in florida, but I dont really have any comment to make about it in my reports and so I usually do not. Any concerns with this rusting away? What is it protecting exactly.
    Thanks!
    Default Re: flashing at bottom plate
    Quote Originally Posted by Jerome W. Young View Post
    Depends on what it is protecting.
    I don't know.
    I've never seen it. Could be:
    - drip edge metal over the edge of the slab with the sill plate on it, with the siding covering the drip edge, with the drip edge acting as a flashing (except that drip edge face looks to be full face and not covered much, if any)
    - drip edge metal over the sill plate with the studs nailed through it to the sill plate, trying to serve as a flashing over the sill plate
    - flat brake metal with the turned out edge installed vertically behind the siding and hanging down to act as a flashing over the sill plate/slab joint
    Regardless, if any of the above, or for any purpose like the above, any flashing which is rusted out needs to be replaced. I can't imagine someone going to that effort without it having been a requirement.
    That said, many areas do not allow galvanized flashings near the ocean, only copper or stainless steel, in which case, this flashing should have been one of those???
    Ron Bibler's Avatar
    Ron Bibler Guest
    Never mind.
    Connecticut
    Looks to me like it's keeping what appears to be hard board siding bottom edge off the concrete.
