Results 1 to 9 of 9
Thread: Pervious Concrete
08-23-2008, 09:22 AM #1
Pervious Concrete
I'm starting to see the installation of pervious concrete for driveways and sidewalks. I have not observed their conditions in the cold northeast yet. Does anyone have experience with observing it's use in freezing conditions? I would assume it will begin to freeze and plug up.
08-23-2008, 01:38 PM #2
Re: Pervious Concrete
Also, I can imagine that cracking will be a problem too, as that stuff has to be weaker than 'ordinary concrete'.
08-23-2008, 02:04 PM #3
08-23-2008, 07:25 PM #4
Pervious, Porous Concrete Pavement Engineering Properties
Seems to have good strength and freeze/thaw applications.
08-23-2008, 11:13 PM #5
Note that the porosity of pervious concrete from the large voids is distinctly different from the microscopic air voids that provide protection to the paste in conventional concrete in a freeze-thaw environment. When the large open voids are saturated, complete freezing can cause severe damage in only a few cycles.
08-24-2008, 03:47 AM #6
08-24-2008, 02:25 PM #7
Freeze-thaw resistance of pervious concrete in the field appears to depend on the saturation level of the voids in the concrete at the time of freezing.
08-24-2008, 06:19 PM #8
My personal opinion is that:
- concrete is very strong in compression
- concrete is very weak in tension
- ice is very strong in expansion forces
- (okay, so those are not "my personal opinions", they are standard opinions shared by most people, including the experts)
- in cold climates water left exposed to the cold freezes
- when water freezes it exerts tremendous expansion forces which can break concrete apart (because of its low tension strength)
- in cold climates, after moisture falls (be it rain or snow), water penetrates down into gaps and cracks
- that water freezes (see above for what happens when it freezes)
08-25-2008, 04:16 AM #9
From the web site under FAQ's
Q: What about freeze-thaw issues?
A: Pervious concrete has been placed in freeze-thaw climates for over 15 years.
Successful applications of pervious concrete in freeze-thaw environments have
two common design features-- the cement paste is air-entrained, and the
pervious concrete is placed on 6–12 inches of drainable aggregate base (¾” or
larger clean gravel).
