I always hate to put water in a pipe...cause now and forever more you have to keep the drain grate clean and the pipe free of debris...but...
In the photo from the crawl space side....
Maybe pour a concrete drainage ditch directly beside the brick so that the top of the ditch is just below the hatch opening to the crawl space and dump the water out to a lower section of the lawn?
Looking from the septic side photo...
It's hard to judge from the photo (Scott what do you think)...it looks like the ground is falling from meter base in the background to the photo in the foreground...if that is the case...run the drain towards the sewer...then out into the lawn...
Anyways...the grading is terrible...like Scott says...the lawn should fall away...
Rule of thumb is about 6" fall in 10'-0"...The next best thing (besides removing the septic) would be to channel the water at it's lowest point...
Home
Home Inspections in Central MS
