LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 06-05-2007, 03:59 PM
Terence McCann Terence McCann is offline
Fuzzy wood under front porch
What causes the wood to start deteriorating like this, a fungus?
tia
Old 06-05-2007, 04:30 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: Fuzzy wood under front porch
High moisture levels in the crawlspace would be at the top of my list of suspects. And high moisture could lead to fungus growth (including mold).
Did you notice standing water or wet soil in the crawl? A plumbing leak? Improper grading around the foundation? Clothes dryer or bathroom exhaust fans discharging into the crawl?
Did you check the floor framing with a moisture meter?
Anyway, it appears that house will need quite a bit of floor framing repairs.
Bruce Breedlove
www.avaloninspection.com
Old 06-05-2007, 04:35 PM
Rick Cantrell Rick Cantrell is offline
That looks bad, really bad.
I was under a house almost that bad about a year ago, within an hour I had a screaming headache and had to go home.
Rick Cantrell
Old 06-05-2007, 05:00 PM
Funny you should mention the headache, I've taken 7 aspirin so far and my head is still pounding - the kind that gets you right at the base of the noggin at the back of the neck.
This was under the front porch, no crawl and plenty of ventilation.
Old 06-05-2007, 05:04 PM
Chip O'Brian Chip O'Brian is offline
And why do I wear N-95 mask in all attic & crawl spaces?
  #6 (permalink)
Old 06-05-2007, 05:17 PM
Chip
That's good advice, for all.
Rick Cantrell
  #7 (permalink)
Old 02-28-2008, 01:04 PM
Greg D. Dames's Avatar
Greg D. Dames Greg D. Dames is offline
Cannot be sure without testing but this could be "Poria Incrassata". The attached photo was taken off the web. NACHI has an article on the one in the photograph. Another name is "House Eating Fungus"
Looking at the photo that you furnished it almost appears that there is a tap root dropping down from the beam in low center of the photo. This is typical as the fungus draws water from the ground.
This stuff is bad news.
Avoiding Litigation: A House-Eating Fungus - InterNACHI
Greg D. Dames
Pacific Mold Assessment
  #8 (permalink)
Old 02-28-2008, 02:03 PM
Jon Randolph Jon Randolph is offline
Quote:
I actually wear a 1/2 face respirator. You get a much better seal and the dust covers over the cartridges can be replaced. I also wear it in attics in old houses.
About $35 at the orange box.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
  #9 (permalink)
Old 02-29-2008, 08:29 PM
Richard Rushing's Avatar
It takes a while, but after a few years, the moisture damage from that fungii makes the wood as soft and brittle as balsa-wood.
Yes... that crap will turn your respritory system to mush also.
RR
Richard Rushing, HCRI
Duncanville, Tx.
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/exterior-systems-home-inspection-commercial-inspection/1487-fuzzy-wood-under-front-porch.html
Posted By For Type Date
and would like your opinion on the following information. This thread Refback 06-12-2007 09:58 AM
Similar Threads
Fuzzy Shingles Nolan Kienitz Roofing System: Home Inspection and Commercial Inspection 4 06-02-2007 05:25 PM
Wood Structural Panel Sheathing or Siding Used to Resist Combined Shear & Uplift Brian Hannigan Building Envelope: Home Inspection and Commercial Inspection 0 05-23-2007 01:16 PM
Exposed wood joist in return air John Tullous Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 15 05-08-2007 07:27 PM
Front Porch Roof Support K Robertson Exterior Systems: Home Inspection and Commercial Inspection 20 05-03-2007 04:26 PM
Wood Burning Fireplace Dale W. Feb Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 12 04-16-2007 03:08 PM
vB.Sponsors
Ad Management by RedTyger
