06-09-2007, 06:26 AM
electric eye height
Is there a code height for the electric eyes? My guess would be 8 inches but not sure. These today appearred toooooooooooo low and just thought i'd ask. Thanks, Wayne
06-09-2007, 07:24 AM
Re: electric eye height
The DASMA technical data sheet says no more than 6 inches from floor. I think most manufacturers recommend 4-6 inches.
Dave
06-09-2007, 04:35 PM
4-6 inches is the maximum recommended height.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
06-09-2008, 08:09 PM
I guess this should be more obvious than it is to me...
The document indicates 4-6 inches above the floor. I am assuming we are measuring the actual location of the "eye" above the floor, not to the eye case.
Recently had quite a few where the eye measured significantly out of specifications. I am just trying to cover my anatomy so when the builder calls and complains because he measured from point X and I am measuring from point Y. I generally include a photo in the report.
06-09-2008, 08:16 PM
From the posted document:
Is
photoelectric eye beam no higher than 6 inches above the floor, or can it be verified via the door manufacturer that photoelectric eyes are not necessary if not present?
Mr. Inspector.net, Inc.
Allen, Texas 75002
06-09-2008, 08:19 PM
Bruce,
Unless you find an installation instructions which says something other than to mount the photoelectric eye beam ... (yes, that) ... between 4" and 6" above the floor, then the photoelectric eye beam ... (yes that) is what is being referenced.
From David's link to DASMA: (underlining is mine)
- 8. Photoelectric Eyes Location: The door may be either fully open or fully closed for this inspection. Note whether photoelectric eyes are present, and if so, locate and measure the distance of photoelectric eye beam from floor. Is photoelectric eye beam no higher than 6 inches above the floor, or can it be verified via the door manufacturer that photoelectric eyes are not necessary if not present?
06-09-2008, 08:20 PM
Beat you Jerry.
Allen, Texas 75002
06-09-2008, 08:26 PM
Only 'cause I had to type more ...
06-09-2008, 08:33 PM
Succinct or verbose, your choice.
Allen, Texas 75002
06-10-2008, 09:17 AM
Thanks!
or
Thank you for the the clarification of the the reference material.
06-10-2008, 10:39 AM
Your welcome.
or
Your thanks is duly noted and the assistance provided is given with well wishes with no further thought of recompense.
Jim
Allen, Texas 75002
| Thread Tools |
Search this Thread |
