Old 10-04-2009, 07:46 AM
CHARLIE VAN FLEET's Avatar
CHARLIE VAN FLEET CHARLIE VAN FLEET is offline
GAURDRAILS AROUND DECK
hi all
did a house yesterday and there was a deck that was 27" to be exact above ground and did not have a gaurdrail. pointed this out to seller who showed up at end of inspection and he said city said it could be 38 inches and did not require rail. my recollection is 24" max
any input here
thanks
charlie
IC Home Inspection Report Writing
Old 10-04-2009, 08:56 AM
Steve Frederickson Steve Frederickson is offline
Re: GAURDRAILS AROUND DECK
Assuming that they're using IRC:
"R312.1 Guards.
Porches, balconies, ramps or raised floor surfaces located more than 30 inches (762 mm) above the floor or grade below shall have guards not less than 36 inches (914 mm) in height."
Old 10-04-2009, 10:15 AM
Gunnar Alquist's Avatar
In a case like that, I will state that a guardrail may not be required, but installation of a guardrail will increase safety.
We have enough youth, how about a fountain of Smart?
Old 10-04-2009, 10:40 AM
Jerry Peck's Avatar
Re: GUARDRAILS AROUND DECK
I would always explain to my clients that, do you really think that 3" is going to injure you any less?
They get it right away.
Old 10-05-2009, 02:35 AM
ben jacks ben jacks is offline
Would that coincide with a quote from the clients attorney? 8j...rbj
  #6 (permalink)
Old 10-05-2009, 05:02 AM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
I would add that the built-in benches add enough height to require railings. Children, and stupid adults (which is most of them - like your AHJ for example) do not always distinguish between the horizontal portion of the deck intended to be walked upon and that which is intended to support fat asses.
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
  #7 (permalink)
Old 10-05-2009, 05:32 AM
Stephen Houmard's Avatar
Stephen Houmard Stephen Houmard is offline
When thiking of deck saftey I use the rule ," What would my drunk friends do?" Railing, seats, steps.....dancing with fat women....how would they hurt themself
IRC is the min code for saftey...think higher.
  #8 (permalink)
Old 10-05-2009, 06:25 PM
Rob Yarboro Rob Yarboro is offline
Guardrails are a good idea, sorry, I thought they were racing on the deck. Nevermind.
  #9 (permalink)
Old 10-05-2009, 07:19 PM
ROB
what did all that mean
charlie
  #10 (permalink)
Old 10-05-2009, 08:56 PM
I read guardrails and thought what's around a racetrack. Sorry, I'll plead a blonde moment.
  #11 (permalink)
Old 10-06-2009, 05:25 PM
Door Guy Door Guy is offline
If the owner was there at the end of the inspection and thought the height was 38" for requiring a gaurd rail, then good luck on convincing him 27" is unsafe. He's within the 30" max. I would just move on with this one.
  #12 (permalink)
Old 10-06-2009, 10:38 PM
Mitchell Toelle Mitchell Toelle is offline
Quote:
I guess that's why you're just the "Door Guy". Bad advice.
Mitch Toelle
HomeAware Property Inspections
Bakersfield, CA 661-204-5747
  #13 (permalink)
Old 10-07-2009, 02:34 PM
John Kogel's Avatar
John Kogel John Kogel is online now
I recommend 6" of bark mulch for a soft safe landing........
  #14 (permalink)
Old 10-07-2009, 02:39 PM
Quote:
Good idea John,
Does this imply that the grade-deck height reduction may permit avoiding the original code requirement? rbj
  #15 (permalink)
Old 10-07-2009, 10:50 PM
John Kogel's Avatar
Quote:
Originally Posted by ben jacks View Post
Good idea John,
Yep. Make that 7 1/2" of mulch and eliminate one riser on the steps too.
  #16 (permalink)
Old 10-08-2009, 10:02 AM
Glenn Duxbury Glenn Duxbury is offline
Hi, all &
It's 24" up-here in good ol' Canada (B.C. - West Coast -to be more precise)...
Just 'maybe' that Owner has already taken a 'HEADER" of his own Deck & that is why his logic is so 'bent' on the subject ?
CHEERS !
-Glenn Duxbury, CHI
-Glenn Duxbury, CHI
  #17 (permalink)
Old 10-08-2009, 12:10 PM
Quote:
Originally Posted by Glenn Duxbury View Post
Hi, all &
CHEERS !
-Glenn Duxbury, CHI
With the 7.5" mulch, that means John won't need to hire a stair carpenter in B.C. 8j rbj
  #18 (permalink)
Old 10-08-2009, 07:13 PM
Jerry Peck's Avatar
With 6", 7", 8" of mulch ... I'd rather fall onto some nice grass, that mulch is no pleasure to fall onto - that mulch stuff can stick up in all the wrong directions, and it hurts.
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Similar Threads
Where's the deck Ryan Stouffer Exterior Systems: Home Inspection and Commercial Inspection 10 09-04-2009 07:56 PM
Big Deck David Banks General Chit Chat: Home Inspectors & Commercial Inspectors 0 03-09-2008 02:35 PM
Deck Construction Scott Latosky Exterior Systems: Home Inspection and Commercial Inspection 6 02-26-2008 02:38 PM
Deck Spindles Matt Fellman Exterior Systems: Home Inspection and Commercial Inspection 1 01-09-2008 06:32 AM
Deck framing wayne soper Exterior Systems: Home Inspection and Commercial Inspection 4 05-02-2007 07:49 AM
vB.Sponsors
Ad Management by RedTyger
