Old 10-14-2009, 03:45 PM
Scott Patterson's Avatar
Need help with ID of trim boards
I need some help and or information on a type of trim board I have never seen It has been used on a home that has Hardy plank siding on it. A critter, most likely a squirrel has been gnawing on sections of it.
The inside of the board is a hard white almost crystalline material. I have no idea what it is. Any ideas??
Scott Patterson
United Infrared
Old 10-14-2009, 03:55 PM
Jerry Peck's Avatar
Re: Need help with ID of trim boards
Scott,
From the photos it looks like some type of foam.
Did it look that way from your vantage point up close?
Old 10-14-2009, 04:01 PM
H.G. Watson, Sr.'s Avatar
H.G. Watson, Sr. H.G. Watson, Sr. is offline
May have been an Architectural Foam Molding (Moulding), made of EPS (expanded polystyrene). Most of what I have seen usually has a hard white shell on the exterior side and are considered paintable. I've usually encountered these as applied on masonry, stucco, EIFS, and with some residing projects involving vinyl, aluminum, and composite siding.
Squirels, racoons, mice, rats, and other critters are not phased by its presence - they chew through the exterior "shell" and right on through it. On the other hand it is thought to be termite proof (although I have seen carpenter ants infest behind it).
Old 10-14-2009, 04:03 PM
Found a link picturing some examples on the www.
Architectural foam,arches,columns,mouldings,home remodeling,staining,additions,Modern Home Improvements Inc
Old 10-14-2009, 04:08 PM
Jerry Peck's Avatar
Quote:
The foam I have in mind is that much finer grained stuff like is used for the interior plastic (or foam, which ever it is) molding which have the wood look material wrapped around them.
What it looks like to me is not EPS, but is much finer grained.
However, it is susceptible to the same problems as the EPS foam H. G. referred to.
Also, while termites do not eat EPS, they do tunnel through it to wood inside.
  #6 (permalink)
Old 10-14-2009, 04:34 PM
This was not like any foam I have ever seen. It was hard and I could chip it out with a screwdriver almost like sandstone. I guess it almost had the density of pumice.
Scott Patterson
  #7 (permalink)
Old 10-14-2009, 04:40 PM
See if you can get a sample of "FoamStone" sent to you, see if it seems similar after you chip off the surface and let it be exposed to the elements for a year of seasonal shifts.
I can't see the detail in the photos that indicate anything other than what I've described.
It doesn't look like Harditrim to me in the pictures but that's about how I'd describe it assuming you had to use a screwdriver to chip it.
  #8 (permalink)
Old 10-14-2009, 05:18 PM
Jerry Peck's Avatar
What I have in mind is XPS, extruded polystyrene. That is a lot denser that EPS (expanded polystyrene).
While that could be high density urethane foam, that is white in color and most urethane foam is yellowish in color. Urethane foam is available in 40 pounds per cubic foot densities, probably even greater, so it makes for a very dense foam too.
  #9 (permalink)
Old 10-14-2009, 07:21 PM
A.D. Miller's Avatar
A.D. Miller A.D. Miller is offline
It could be cellular foam concrete being used as mortar. I have seen this stuff applied, but not to fiber-cement siding. Looks like a nightmare to me.
"What the plainspoken man lacks in subtlety he makes up in clarity." - A.D. Miller
www.texasinspector.com
  #10 (permalink)
Old 10-14-2009, 08:50 PM
fritzkelly fritzkelly is offline
Scott, that look identical to some baseboard I bought recently at Home Depot. Dense urethane foam and white. No idea if it is rated for exterior use. Probably made from peanut oil
"Some people are like slinkies. They serve absolutely no useful purpose. But still put a smile on your face when pushed down a flight of stairs."
  #11 (permalink)
Old 10-14-2009, 08:53 PM
Jerry Peck's Avatar
Quote:
Fritz,
That's the stuff I'm referring to. You sure it is urethane and not extruded polystyrene? Could be urethane.
  #12 (permalink)
Old 10-14-2009, 09:06 PM
Actually, I'm not sure. I guess plastic is plastic but you are correct, urethane is usually tan or yellow, I would say you are probably correct, a dense polystyrene.
  #13 (permalink)
Old 10-15-2009, 07:29 AM
This is a vacant REO house way out in the country, I might just go back out and see if I can snatch a small piece of the trim away from one of those critters to see if I can figure it out.
Scott Patterson
  #14 (permalink)
Old 10-17-2009, 06:10 PM
John Kogel's Avatar
John Kogel John Kogel is offline
Quote:
Don't nobody feed the squirrels where you are, Scott?
If that squirrel was standing on the ground when he did that, could be a PCB mutant. Watch your back out there.
IC Home Inspection Report Writing
Similar Threads
Badly cut boards in rafters--be concerned? Dan Hallock Attic Areas: Home Inspection and Commercial Inspection 2 10-26-2009 02:04 PM
Badly cut boards in rafters--be concerned? Dan Hallock Attic Areas: Home Inspection and Commercial Inspection 16 09-09-2009 07:07 AM
COMPOSITE TRIM BOARDS Milton Grew Building Envelope: Home Inspection and Commercial Inspection 1 08-03-2009 05:47 AM
Unused wire and splices in panel boards Tom McDonnell Electrical Systems: Home Inspection and Commercial Inspection 5 06-04-2009 08:44 PM
form boards left in place wes owens Sub-Structure: Home Inspection and Commercial Inspection 10 01-14-2008 10:43 AM
vB.Sponsors
Ad Management by RedTyger
