Old 07-06-2007, 10:29 AM
Construction Joint needed?
Old 07-06-2007, 10:42 AM
Frank Kunselman Frank Kunselman is offline
Re: Construction Joint needed?
There probably is, under the stone. The joint that's there should be caulked between the stone and the concrete.
Old 07-06-2007, 12:45 PM
Martin lehman's Avatar
Martin lehman Martin lehman is offline
Having that concrete planter with soil installed against the wall w/o an air gap is going to deteriorated the wall framing. I call it all the time.
Similar Threads
7 year old construction Victor DaGraca Attic Areas: Home Inspection and Commercial Inspection 10 06-17-2007 03:42 PM
What is the proper construction details? Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 1 06-01-2007 08:44 AM
New Construction-- no one will notice Richard Rushing Roofing System: Home Inspection and Commercial Inspection 2 05-09-2007 10:15 PM
Skylight flashing new construction Eric Shuman Roofing System: Home Inspection and Commercial Inspection 1 05-03-2007 05:52 AM
Brick Veneer Exterior Wall 90 deg inside joint imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 2 04-05-2007 07:52 PM
vB.Sponsors
Ad Management by RedTyger
