Old 07-15-2007, 08:22 PM
william siegel's Avatar
william siegel william siegel is offline
Front entry step
The sellers installed pavers up to the front door. Now the riser off the front landing is about 1 1/2 inches. Does the miminum riser requirement apply here?
I have noted / mentioned it as a trip hazard. Is there a code citatiion requirement for this? Thanks in advance.
Bill Siegel
Florida Home Inspection Team Inc.
Old 07-15-2007, 08:54 PM
Gunnar Alquist's Avatar
Re: Front entry step
William,
The UBC (now the CBC in California) allows for a step up that does not exceed 8" at a doorway, provided the door does not open over the landing. I would assume that the IRC or Florida code has a similar provision. It looks like the door in your pic opens over the landing and, per code, the difference between the threshold and landing should not exceed 1". Screen and storm doors are excepted. Without measuring, the doorway in your pic does not look bad.
The apostrophe troll.
Similar Threads
Fuzzy wood under front porch Terence McCann Exterior Systems: Home Inspection and Commercial Inspection 8 02-29-2008 08:29 PM
Water front, boat docks RobertSmith Exterior Systems: Home Inspection and Commercial Inspection 2 07-06-2007 11:05 AM
New construction - stair step cracks Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 06-02-2007 07:58 PM
Front Porch Roof Support K Robertson Exterior Systems: Home Inspection and Commercial Inspection 20 05-03-2007 04:26 PM
Inspection Radio - Getting Started - Step 1 Carlos Tabora Tutorials and Training 2 04-18-2007 01:17 PM
vB.Sponsors
Ad Management by RedTyger
