Old 07-22-2007, 11:16 AM
Randy Moore Randy Moore is offline
Garage Floor Cracks - New Construction
New home with garage concrete deck cracking parallel to rear house wall, also down the middle. I'm thinking the heavier heated section of the house settled causing the thinner garage concrete deck to crack under the stress. Thoughts?
Home inspection
Old 07-22-2007, 12:58 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Re: Garage Floor Cracks - New Construction
I don't see a control joint. That would explain the one down the center of the slab.
Bruce Breedlove
www.avaloninspection.com
Old 07-22-2007, 04:07 PM
Nick Ostrowski Nick Ostrowski is offline
Are those moisture stains around the crack in pic #2?
Old 07-22-2007, 04:15 PM
Rick Hurst's Avatar
Maybe its the weight of the water heater sitting directly on the floor.
50 gal. at 7+lbs. / Gal. + the tank vessel. Nope that shouldn't have done it.
Was there any cracks in the exterior foundation beam walls opposite those cracks?
Those look larger than the normal to observe curing cracks.
Old 07-23-2007, 03:47 AM
Eric Van De Ven's Avatar
Eric Van De Ven Eric Van De Ven is offline
Quote:
I would recommend that an engineer and the builder be called to address this issue. I have seen in several instances, where during the initial pour of the main slab, the cement truck parks right where the garage floor is supposed to be. After the main slab is poured, the truck moves, the displaced soil is raked back into place, not compacted, and then the slab is poured for the garage.
If you were to drill a few holes near the cracks, you would probably find out that the slab is only 2 inches, or less, thick.
Eric Van De Ven Magnum Inspections Inc. (954) 340-6615
www.magnuminspections.com
  #6 (permalink)
Old 07-23-2007, 12:54 PM
Rick - I looked hard at the foundation but didn't see any cracking there.
Eric - good call, that was my recommendation. My thought is that the builder went cheap with a too-thin garage slab that couldn't take any settling stress, especially if the heavier house settled a bit. I'd like to see the eng analysis.
Pristine Home Inspections, Hudson, FL
www.pristineinspections.net
  #7 (permalink)
Old 07-23-2007, 07:57 PM
John Goad John Goad is offline
A lot of times if re-bar dowels are not put into the foundation when the floor is poured there will be settling at that area resulting in that crack.
Similar Threads
Cracks in flue Phillip Stojanik Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 22 07-18-2007 05:12 PM
Cracks, cosmetic or structural RobertSmith Building Interior: Home Inspection and Commercial Inspection 10 07-14-2007 04:17 PM
Cracks in garage slab dan orourke Building Interior: Home Inspection and Commercial Inspection 4 06-24-2007 01:14 AM
New construction - stair step cracks Jeff Eastman Building Envelope: Home Inspection and Commercial Inspection 2 06-02-2007 07:58 PM
wall/floor cracks Vince Santos Structural Components: Home Inspection and Commercial Inspection 2 05-07-2007 08:43 AM
vB.Sponsors
Ad Management by RedTyger
