Old 09-18-2007, 02:39 PM
Sean Bacon Sean Bacon is offline
Can this be saved or should it be torn down?
Came across this during an inspection this morning. Bank Foreclosed property, approximately 10-15 year old frame addition (because it has metal siding) in the rear of a masonry home (at this point no idea if it was done by permit). There was significant termite damage noted at the sill plates and lower studs of at least three walls up through the to the second floor windows. In addition, the slab that it was built on sloped to ground level from a point of about 3" (front to rear). Mold noted along lower portion of walls. Also, they appeared to use sheetrock on the outside of the studs where normally plywood or OSB would be? Was this a general practice back then? I know that we don't determine how this should be repaired, but for my own knowledge, Can this be repaired or should it be razed and redone. My initial thinking is with slab height being inadequate for a structure, moisture intrusion would always be a problem. As well as, the significant termite damage might make it necessary for extensive repairs.
Thanks for any comments.
Old 09-18-2007, 03:14 PM
Richard Rushing's Avatar
Re: Can this be saved or should it be torn down?
Can this be saved? Probably... but why would anyone want to put good money after bad?
Wood rot, poor construction, poor flashing, bad materials, mold, termites.... this thing has it all.
There are only 5 things that can cause a problem:
Materials, Methods, Man-power, Machinery, Management--- this one is 5 for 5! Tear-er down, say I.
rr
Richard Rushing, HCRI
Duncanville, Tx.
Old 09-18-2007, 03:18 PM
Rick Hurst's Avatar
Why spend good money dressing up a turd?
Put it out of its misery. I'm sure the neighbors won't mind a bit.
Old 09-18-2007, 05:16 PM
In the Army we had an old saying.... "You can't polish a turd"
No matter how hard you rub or polish, it's still a piece of shee!!t.
Duncanville, Tx.
Old 09-18-2007, 05:25 PM
Jim Luttrall Jim Luttrall is online now
Sean, the addition should come down.
The "Sheetrock" is likely exterior grade gypsum sheathing. Common for use behind brick and other sidings. I think it is still used today in commercial construction.
Jim
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #6 (permalink)
Old 09-18-2007, 10:03 PM
Jon Randolph Jon Randolph is offline
I disagree with most. Everything can be repaired with pockets that are deep enough. If you like the design and everything, just replace the defective parts with new and you should be good for another 5-10 years before you have to re-do it again. Just think of the knowledge that you can pick up and make it easier the next time. You can even save money if you don't treat the WDI. That will help you re-live the experience even quicker.
On the other hand, if you don't want to keep spending money trying to make a turd look good, tearing it down, treating for the WDI and re-building would be prudent.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
  #7 (permalink)
Old 09-18-2007, 10:20 PM
Guys, thanks for the responses...
vB.Sponsors
Ad Management by RedTyger
