Old 09-23-2007, 03:06 PM
Clay E White Clay E White is offline
Drainage under walkway
Old 09-23-2007, 03:13 PM
Rick Hurst's Avatar
Re: Drainage under walkway
Clay,
The wood was just use to form the opening.
Not a problem in my opinion. Where its located, let the termites enjoy it.
Old 09-23-2007, 03:15 PM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
The OSB are portions of the left over forms they built for the concrete pour, a piece of drain pipe would have been simpler and better, but oh well.
I'd note it and move on, rather have bugs show up here than at the house. Think of them as little garbagemen removing unwanted debris.
Rick,
Slow down I was typing
Residential-Commercial-Construction-EIFS-Infrared Thermography
Old 09-23-2007, 08:47 PM
ALL forms must be removed, unless made to become a permanent part of the formed construction - and wood is not "permanent", not unless it is one of the 'permanent wood species' listed in the code (and, no, OSB is not one of them).
Home inspection
Similar Threads
condensate pump drainage wayne soper Plumbing System: Home Inspection and Commercial Inspection 5 03-10-2008 08:08 PM
Grading and drainage imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 5 07-27-2007 06:49 PM
Walkway? John Goad Exterior Systems: Home Inspection and Commercial Inspection 3 06-17-2007 02:56 PM
Drainage Advice Needed Phillip Joyner, Jr. Exterior Systems: Home Inspection and Commercial Inspection 10 06-10-2007 05:17 PM
Loud gurlging noises - sink/tub drainage John Stephenson Plumbing System: Home Inspection and Commercial Inspection 5 05-16-2007 09:57 PM
vB.Sponsors
Ad Management by RedTyger
