Old 09-27-2007, 11:41 AM
David Edens David Edens is offline
Foundation level "drain"
Have a question in regards to what looks like a (one) pipe fitted hole of about 4" in diameter that I have seen at foundation/grade level on several houses with a crawlspace. Is this where a DWV pipe was possibly supposed to go, but was laid out wrong in the configuation? It does have the DWV going out somewhere else. Or is this some sort of drain hook-up? Any help would be appreicated!
Home inspection
Old 09-27-2007, 11:50 AM
Rick Hurst's Avatar
Re: Foundation level "drain"
It sounds like your seeing a sewer cleanout pipe.
Old 09-27-2007, 11:54 AM
Well, on a couple of occasions, I have seen this where there is no pipe present, just the hole at foundation/grade level--as if a DWV pipe was supposed to go there.
Old 09-27-2007, 02:22 PM
Quote:
Probably was.
Any time a plumbing pipe goes through a foundation wall or footing, it is required to be sleeved with a sleeve two sizes larger than the pipe to go through the foundation wall.
If the sleeve is in the wrong location, they leave it (it's cast into the concrete and you have to either break it out or leave it there) and make a new hole for at the new location. Of course, though, they usually forget about the "two sizes larger" thing, especially when relocating it.
Old 09-28-2007, 08:24 AM
That's it guys, thanks!
  #6 (permalink)
Old 09-28-2007, 08:37 AM
John Goad John Goad is offline
If it's in the corner it's probably the positive drain for the crawl area.
  #7 (permalink)
Old 09-28-2007, 08:42 AM
I may have mis-understood your post, the positive drain for the crawl area I am referring to would be in a corner at the "footing", sorry.
Home inspection
Similar Threads
"Fireblock" or "separation" Jeff Eastman Building Interior: Home Inspection and Commercial Inspection 9 10-16-2007 06:27 PM
"Type of Branch Circuit Wiring" - Texas RobertSmith Electrical Systems: Home Inspection and Commercial Inspection 5 07-19-2007 09:21 PM
"Drain Gurgling" dan orourke Plumbing System: Home Inspection and Commercial Inspection 1 07-13-2007 05:25 PM
"Flip This House" Star Arrested For Fraud Bruce Breedlove General Chit Chat: Home Inspectors & Commercial Inspectors 2 06-03-2007 08:04 AM
White "powder" at furnace exhaust tube Terry Beck Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 0 04-26-2007 11:00 PM
vB.Sponsors
Ad Management by RedTyger
