Originally Posted by
Chip O'Brian
Tell me the good news.
Rick Hurst
Good news is that is not Jerry's house.
Rick, you got that right!
Chip O'Brian
Build 2005 with in .25 mile to beach 2 story off grade.
Is that high enough to be above flood level (DFE and BFE)? In Destin? I would think that that would need to be higher, with frangible walls (breakaway walls) down to grade from DFE/BFE as that is most likely a V flood zone (V=velocity, meaning wave action). At least I would think so at only 1/4 mile in. If it is in Destin, have you contacted Noel (now Chief Inspector) or Larry Ballard (Building Official) - I worked with both last year when I was doing municipal support for Larry while Noel and Larry were alternating taking vacation time off before they lost it.
Skirting is 2X6 wood appears tounged, no air gaps.
See above.
Wood in contact with ground or below.
Would need to be pressure treated and then you have the problem of termite tunneling up it and not being seen. Not good.
1) No air flow in floor space primarly sealed.
2) Wood incontact with ground.
See above.
What is that wood siding on? If wood framing, it would be too close to grade, unless pressure treated, then what type of termite protection was used, etc.?
3) Could not inspect crawl seal door in pic 3
4) Shot a photo of underfloor at hole pic 4 appears spray foam insulation.
I'm not sure that that insulation is intended to be used for exposed floor crawlspace areas. Also, not only was there insufficient space in the crawlspace for you to crawl, but it was also insufficient for the person who sprayed on that insulation as it looks way too thin to meet much of any R-value, and, yes, I see the ope space, looks rectangular, like something was there when the insulation was sprayed on, then it was removed, leaving the opening.
Good news? At least the pipes are insulated with some type of insulation, albeit unknown type or R-value, but, no R-value is specified for insulation, it's *whatever works*.
Looks like pressure treated joists. The girder in the distance looks too close to the ground. With pressure treated, though, I think the height above grade can be quite low, but that does not address termite treatment or termite accessibility (making termites only tunnel a short way is like you having a supermarket move in next door - your food source now requires much less walking to reach
Then, of course, do not forget all that organic matter (the branches or whatever they are) laying on the ground and reaching up toward the wood floor system. Nothing like building a private walkway to that new supermarket which moved in next door to you.
