Old 11-06-2007, 07:15 AM
Clay White Clay White is offline
Handrail termination
Old 11-06-2007, 08:20 AM
Bruce Ramsey's Avatar
Bruce Ramsey Bruce Ramsey is online now
Re: Handrail termination
What circle?
Bruce Ramsey
Advocate Inspections
www.NCAdvocate.com
Old 11-06-2007, 08:31 AM
David Banks David Banks is offline
Clay. That sure is different. The landing does not need a handrail but was probably put there for a frail or elderly person. Sure looks like one could snag clothes or handbag at the jog in the handrail. Handrail height looks low. Should be 34-38 inches.
Dave
Old 11-06-2007, 11:47 AM
Chris Roust Chris Roust is offline
I would not report this. The handrail is continuous and does not present the open end that would snag on a purse strap or clothing. If it returned to the post, it would present the same 90 degree angle and would not be considered a problem.
Old 11-06-2007, 02:13 PM
If the far end is against the wall, it would be okay (no circled area to go by).
Otherwise, as stated by the others above, it is continuous and is okay.
  #6 (permalink)
Old 11-06-2007, 03:12 PM
Scott Patterson's Avatar
Quote:
Originally Posted by Clay White View Post
Would you agree the handrail (see circled area) should terminate into the guardrailing at this point? Seems to me its not terminated.
Why would it need to terminate? Returns are for when the handrails are open on the ends.
Scott Patterson
Home inspection
Similar Threads
Handrail Rick Hurst Building Interior: Home Inspection and Commercial Inspection 24 08-28-2008 04:40 PM
Plumbing vent termination Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 14 07-17-2008 07:11 PM
WH vent termination from headwall Clay White Plumbing System: Home Inspection and Commercial Inspection 16 11-01-2007 04:57 PM
Vent termination Dave Gilstrap Plumbing System: Home Inspection and Commercial Inspection 2 10-19-2007 10:13 AM
Catch pan drain termination Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 11 04-30-2007 04:19 PM
vB.Sponsors
Ad Management by RedTyger
