Originally Posted by
Clay White
David,
I'm not concerned with the clearance FOR the gas meter. I'm concerned about the clearance for walking between the gas meter and fence. 2feet seems narrow!
Clay. Sorry misunderstood your question as did others. I know of no walkway standard. You stated. I measured from where approximately the gas meter would be located to the fence (24")....is there any standard, requirment on distance for walkpath in a yard (like in a hallway). Seems 24" would be too narrow.
I gave you a standard from PDF for Puget sound area and stated Local utility may differ as did Rick. I think your splitting hairs here. Not sure why you are concerned about clearance for walking between the gas meter and fence and not "structures that restrict access to meter set assembly" as stated in PDF. 3 FT to fence. To each there own. Just trying to help.
