Old 12-11-2007, 04:03 PM
Michael Thomas's Avatar
Michael Thomas Michael Thomas is online now
Grading and drainage requirments
We always give advice about grading away from a structure “one inch per foot for the first ten feet” or the like, but I just realized that beyond common sense I don't have a cite for the requirement. Is in the IRC, or is it some sort of standard from civil engineering, or what?
Ditto for 6' on downspout discharge from structure.
Old 12-11-2007, 04:40 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: Grading and drainage requirments
Michael,
I'll bite.
IRC 2003 R202 Definitions Grade Plane-------------------------Where the finished ground level slopes away from the exterior walls,----------------------------------------------.
Also: IRC 2003 R401.3 Drainage.----------------------------------The grade away from the foundation shall fall a minimum of 6 inches within the first 10 feet.
Billy J. Stephens HI Service
Old 12-11-2007, 06:18 PM
Thanks.
Now, about the downspouts being 6' out...
Old 12-11-2007, 06:23 PM
Also, I've got this in my notes, but from where?
"The final grade should provide a minimum slope of one-half unit vertical in 12 units horizontal for a minimum of 6 feet from the home"
Old 12-11-2007, 06:56 PM
IRC 2003 R202 Grade Plane
Gutters? Anyone? 6 ft Requirement.
  #6 (permalink)
Old 12-11-2007, 07:13 PM
Jerry McCarthy's Avatar
This is what proper gutter extensions should look like.
Construction Consultant
  #7 (permalink)
Old 12-11-2007, 07:14 PM
Re: Grading and drainage requirements
In Florida the gutter/downspout discharge is required to be at least 12 inches from the foundation wall/slab edge.
Don't know of anything in the IRC.
The purpose is to get the discharging water out past the termite treatment area.
  #8 (permalink)
Old 12-11-2007, 07:15 PM
Jerry Mc.,
Those are just 'outdoor showers'.
http://www.inspectionnews.net/home_i...extension2.jpg
  #9 (permalink)
Old 12-11-2007, 07:50 PM
Quote:
Jerry Mc.,
I hope you wrote up the Improper Clearance from the Ground on that front Siding.
  #10 (permalink)
Old 12-12-2007, 05:49 AM
Darren Miller's Avatar
Darren Miller Darren Miller is offline
R801.3 (NJ edition)
Roof drainage. In areas where expansive or collapsible soils are known to exist, all dwellings shall have a controlled method of water disposal from roofs that will collect and discharge roof drainage to the ground surface at least 5 feet from foundation walls or to an approved drainage system.
Darren
New Jersey Home Inspection - About the House!
  #11 (permalink)
Old 12-12-2007, 06:01 AM
Aaron Miller Aaron Miller is offline
Senior Member
Michael:
The 6" drop in the first 10' out from the foundation perimeter is also a HUD requirement. Additionally, if the foundation is a slab-on-grade, it is a Post-Tensioning Institute requirement. And finally, if this is a new home covered by a warranty or one where the foundation has been repaired and is under warranty, the warranty validity is dependent upon the owner's adherence with this drainage provision.
Aaron
  #12 (permalink)
Old 12-12-2007, 07:56 AM
Rick Hurst's Avatar
Aaron,
Your on the money about the home warranty. I had a PC customer who had filed a claim against the builder / and the home warranty for foundation movement.
As soon as the warranty people came out, they told her she had added those stackable stones around the shrub bed which obstructed the drainage, therefore the warranty was void. According to them, no changes should be made to the original grading whatsoever to keep such a warranty in place.
  #13 (permalink)
Old 12-12-2007, 08:16 AM
Richard Rushing's Avatar
Those same warranty folks will deny a claim if you add shrubs or plant trees. Again, these "Warranty" companies are in business to *make* money, not give it away. They will do what ever necessary to drop a claim.
Rich
Richard Rushing, HCRI
Duncanville, Tx.
  #14 (permalink)
Old 12-12-2007, 09:41 AM
Quote:
Originally Posted by Darren Miller View Post
R801.3 (NJ edition)
Darren
Bingo Thanks Darren,
Also in IRC 2003 R801.3
  #15 (permalink)
Old 12-12-2007, 01:59 PM
Gunnar Alquist's Avatar
Jerry Mc,
Nice personal pic. Much more flattering than the last one. Of course, the same could be said about mine...
The apostrophe troll.
Similar Threads
condensate pump drainage wayne soper Plumbing System: Home Inspection and Commercial Inspection 5 03-10-2008 08:08 PM
Drainage under walkway Clay E White Exterior Systems: Home Inspection and Commercial Inspection 3 09-23-2007 08:47 PM
Grading and drainage imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 5 07-27-2007 06:49 PM
Drainage Advice Needed Phillip Joyner, Jr. Exterior Systems: Home Inspection and Commercial Inspection 10 06-10-2007 05:17 PM
Loud gurlging noises - sink/tub drainage John Stephenson Plumbing System: Home Inspection and Commercial Inspection 5 05-16-2007 09:57 PM
vB.Sponsors
Ad Management by RedTyger
