Old 04-12-2007, 01:46 PM
More Stucco question
Old 04-12-2007, 04:02 PM
Re: More Stucco question
Depends.
Meaning, I can't tell from the photos.
*IF* the stucco was installed on all of that wall 'first', 'then' the wood trim added. probably not.
*IF* the wood trim was installed 'first', 'then' the in-fill areas between the wood trim stuccoed, it absolutely needs all kinds of things to allow for the water getting behind the stucco to drain to the outside.
Similar Threads
Stucco Jeff Eastman Exterior Systems: Home Inspection and Commercial Inspection 3 04-12-2007 07:01 PM
A how to question Jeff Eastman Electrical Systems: Home Inspection and Commercial Inspection 7 04-11-2007 12:03 PM
Question about web links Jack Feldmann Business Operations: Home Inspectors & Commercial Inspectors 9 04-10-2007 03:52 PM
Ceiling Fan 101 question RobertSmith Electrical Systems: Home Inspection and Commercial Inspection 7 04-06-2007 10:50 PM
vB.Sponsors
Ad Management by RedTyger
