Old 02-04-2008, 11:05 AM
CHARLIE VAN FLEET's Avatar
CHARLIE VAN FLEET CHARLIE VAN FLEET is offline
deck posts and footer
came across this yesterday----how would you write it up and recommend---the rest of the deck was sound and construted properly----would you call this the cart before the horse
Home inspection
Old 02-04-2008, 11:15 AM
Re: deck posts and footer
lets try those pictures again
Old 02-04-2008, 12:12 PM
Rick Hurst's Avatar
Its obvious that the posts are not centered over that so called footing.
Be willing to bet that is just some concrete poured within those wooden forms and those forms should have been removed so the termites won't devour them.
Looks like amatuer work.
Old 02-04-2008, 12:35 PM
Eccentrically loaded footings, if that is what those are, provide engineering that the footings are designed for eccentric loading (which will also answer the question of 'if that is what those are').
As Rick said, those wood forms should have been, and need to be, removed, and those footings are also likely to only be skin deep (as deep as the wood forms).
Home inspection
Similar Threads
Deck Spindles Matt Fellman Exterior Systems: Home Inspection and Commercial Inspection 1 01-09-2008 06:32 AM
Deck or Landing Pad Eric Smith Exterior Systems: Home Inspection and Commercial Inspection 15 01-08-2008 06:30 PM
Worst deck ever Jack Feldmann Exterior Systems: Home Inspection and Commercial Inspection 8 12-01-2007 07:28 PM
A new way to build a deck Scott Patterson Exterior Systems: Home Inspection and Commercial Inspection 10 08-28-2007 08:33 PM
Deck framing wayne soper Exterior Systems: Home Inspection and Commercial Inspection 4 05-02-2007 07:49 AM
vB.Sponsors
Ad Management by RedTyger
