Old 02-23-2008, 01:46 PM
Don Jackson Don Jackson is offline
Driveway Drainage
This client has a problem with driveway drainage. He is a Florida resident living in a cul-de-sac. Whenever it rains a fair amount, the end of his driveway collects a pool of water. Being at the end of his driveway and street, I'm not sure how to suggest any remedy. Is it a city matter or is there something he could do to fix the problem?
Old 02-23-2008, 01:56 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Re: Driveway Drainage
Quote:
Originally Posted by Don Jackson View Post
--- Is it a city matter or is there something he could do to fix the problem?
Don,
Other than move? No.
If you reverse the Is it to It is a city problem you have his answer.
I pity the guy behind the fence of that small pond.
Billy J. Stephens HI Service
Old 02-23-2008, 04:51 PM
Jim Zborowski Jim Zborowski is offline
You would hhave to shoot the grade with a tranit to determine if the garage floor is higher than the road. If it is, you could redo the driveway to pitch so water runs onto the road. Without actually seeing it first hand it's hard to say. A good concrete guy may be ableto do some creative flatwork to redirect the water.
Old 02-23-2008, 05:23 PM
Rick Hurst's Avatar
I would probably stock it with some catfish.
Old 02-23-2008, 05:49 PM
Quote:
Jim,
As that would work and may have already been done.
Anything beyond that would involve the City Public works.
There appears to be a storm drain right across the street and the neighbors house behind the end of the coves fence seems to be lower than the street.
  #6 (permalink)
Old 02-23-2008, 06:44 PM
Nick Ostrowski Nick Ostrowski is offline
Looks like the end result of poor planning to me.
  #7 (permalink)
Old 02-24-2008, 05:37 PM
Could be a clogged storm drain.
Could be a storm drain going into a 'dry well'/'french drain' (like is in front of our house - whenever it rains, the storm drain fills and the street floods similar to that, given enough time, the water goes down. We've called the city and they will come out and pump it out, but the problem is that it is not connected to anything, it is a 'dry well' used for that purpose, obviously, the dry well is not of sufficient capacity and the percolation into the soil is not sufficient to drain the water off soon enough.
However, there is another dry well storm drain on the other side of the street (exactly opposite the one on our side) and it drains down quite fast. And, nope, they are not connected. It's the way our subdivision was built.
If there is no storm drain there, then it is a grading problem.
If (IF) the city has jurisdiction over that street, the problem 'might' be theirs.
I would call the city first, you may end up finding out that there is basically nothing which can be done (as we did - but at least ours is not at the driveway).
  #8 (permalink)
Old 02-25-2008, 11:15 AM
Greg D. Dames's Avatar
Greg D. Dames Greg D. Dames is offline
Kids need "Water Wings" to play basketball.
Home inspection
Similar Threads
Driveway/garage slab dan orourke Building Envelope: Home Inspection and Commercial Inspection 4 12-03-2007 07:56 PM
Strange Driveway Detail imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 5 09-08-2007 08:03 AM
Grading and drainage imported_John Smith Exterior Systems: Home Inspection and Commercial Inspection 5 07-27-2007 06:49 PM
crack driveway/house dan orourke Building Envelope: Home Inspection and Commercial Inspection 11 06-08-2007 07:24 PM
Driveway dan orourke Building Envelope: Home Inspection and Commercial Inspection 6 06-01-2007 09:13 PM
vB.Sponsors
Ad Management by RedTyger
