Old 04-26-2007, 12:50 PM
Eric Laney Eric Laney is offline
Freestanding patio cover
just wanted to run this by the group:
1) lumber for headers between posts was Yellowood 1 1/4 x6 deck boards (don't know the exact dimension but it is used as deck flooring, looks like about 1 1/4 by 6). So, it's not a true 2x6 but there was one on each side of the post). Shouldn't these be a true 2x6?
2) Support posts were Yellowood 4x4's embedded in concrete patio slab.Deck was freestanding. Shouldn't the posts have diagonal braces to the headers since it is freestanding? I could push on the post and get the patio cover to sway. Also note the rafter ties attached with screws, some holes not filled.
Home Inspector Essentials. The BEST prices for inspection tools.
Old 04-26-2007, 02:26 PM
wayne soper's Avatar
Re: Freestanding patio cover
If it sways it needs bracing right? Not brain surgery. Bracket to the side wall of the home not a bad idea either.
Old 04-26-2007, 03:03 PM
Jerry Peck's Avatar
1x lumber is 3/4"
2x is 1-1/2"
5/4 is 1-1/4"
It is called 5/4 as that is what you are getting, starts out different than 1x and 2x.
Those diagonal braces would be 'knee braces', and, yes, in most areas, you would want to install them with most construction methods. With enough steel brackets, angles, supports, etc., they would replace the need for knee braces as they would have a certain amount of built-in rigidity.
Nailed or bolted lumber does not make for tight and rigid joints. Meaning things can sway.
I would be careful about anchoring it to the house, you could cause leaks at the attachment points.
If it sways, regardless 'how much steel' is there, it needs bracing, typically that would be diagonal bracing or maybe just knee bracing (knee bracing does not extend down as far as diagonal bracing).
Old 04-27-2007, 05:32 AM
I agree, if it sways it needs bracing. I was hoping for something in the IRC that said so, but I couldn't find any bracing requirements for patio covers.
Old 04-27-2007, 07:09 AM
Jerry Peck's Avatar
Quote:
Eric,
Don't think of it as a "patio cover", think of it as a "structure" ... then apply the rules for a "structure".
  #6 (permalink)
Old 04-30-2007, 10:48 PM
K Robertson's Avatar
K Robertson K Robertson is offline
Quote:
Sometimes all the education, experience, and time spent studying just can't replace good ole fashion common sense.
IC Home Inspection Report Writing
Similar Threads
From the old board, Plywood Patio & Plywood Sidewalk Tim Moreira Building Envelope: Home Inspection and Commercial Inspection 3 04-08-2007 05:00 PM
Table of Contents on the Cover Page? Mike Paris H E L P ! 2 04-02-2007 12:47 AM
vB.Sponsors
Ad Management by RedTyger
