Old 05-20-2008, 01:03 PM
Jerome W. Young Jerome W. Young is offline
flashing at bottom plate
I see this often here in florida, but I dont really have any comment to make about it in my reports and so I usually do not. Any concerns with this rusting away? What is it protecting exactly.
Thanks!
Home inspection
Old 05-20-2008, 08:04 PM
Re: flashing at bottom plate
Quote:
Depends on what it is protecting.
I don't know.
I've never seen it. Could be:
- drip edge metal over the edge of the slab with the sill plate on it, with the siding covering the drip edge, with the drip edge acting as a flashing (except that drip edge face looks to be full face and not covered much, if any)
- drip edge metal over the sill plate with the studs nailed through it to the sill plate, trying to serve as a flashing over the sill plate
- flat brake metal with the turned out edge installed vertically behind the siding and hanging down to act as a flashing over the sill plate/slab joint
Regardless, if any of the above, or for any purpose like the above, any flashing which is rusted out needs to be replaced. I can't imagine someone going to that effort without it having been a requirement.
That said, many areas do not allow galvanized flashings near the ocean, only copper or stainless steel, in which case, this flashing should have been one of those???
Old 05-20-2008, 08:48 PM
Ron Bibler Ron Bibler is offline
Never mind.
Old 05-21-2008, 04:54 AM
wayne soper's Avatar
Looks to me like it's keeping what appears to be hard board siding bottom edge off the concrete.
Home inspection
Similar Threads
Need Opinions - Unsupported Sill Plate Bob Sisson Structural Components: Home Inspection and Commercial Inspection 7 04-02-2008 07:48 PM
Column top plate Jeff Beck Structural Components: Home Inspection and Commercial Inspection 7 02-21-2008 07:37 AM
Condo/Townhouse Boiler Plate Tim Moreira Reports 3 10-16-2007 07:43 AM
Stairway bottom landing John Stephenson Building Interior: Home Inspection and Commercial Inspection 2 06-06-2007 08:33 PM
Opening at bottom of guardrail dan orourke Building Interior: Home Inspection and Commercial Inspection 5 05-07-2007 07:29 PM
vB.Sponsors
Ad Management by RedTyger
