07-04-2008, 09:33 AM
Deck Framing
Rear Deck
- Ledger board attachment is lag screws into OSB.
- Lag screws are counter sunkinto the ledger.
- Ledger attaches over the vinyl siiding without flashing. Water staining present on the OSB at the interior.
- Center beam is nailed together without support.
- Fasteners are corroded at the joist hangers.
- Poor framing of the stairway
- Loose handrails with 6 inch spacing of balusters.
07-04-2008, 10:14 AM
Re: Deck Framing
I bet those joist hangers are not made for treated wood. I see this more and more, especially with the fasteners.
07-05-2008, 04:41 AM
Re: Deck Framing
Here's four more problems:
1) Open risers
2) uneven risers (short step on bottom)
3) 'Split' beam attachment to posts improper
4) Handrail not graspable
Ah, but the agent said it was approved by the town so it MUST be OK
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Framing question |
mathew stouffer |
Structural Components: Home Inspection and Commercial Inspection |
15 |
06-15-2008 10:07 AM |
| Rough Framing |
Aaron Miller |
Building Interior: Home Inspection and Commercial Inspection |
12 |
05-10-2008 11:12 AM |
| Framing strut |
Jeff Eastman |
Attic Areas: Home Inspection and Commercial Inspection |
2 |
12-15-2007 07:00 PM |
| Deck framing |
wayne soper |
Exterior Systems: Home Inspection and Commercial Inspection |
4 |
05-02-2007 06:49 AM |
| Steel framing |
Phillip Stojanik |
6 |
04-14-2007 01:21 PM |
Ad Management by
RedTyger
