08-04-2008, 08:54 AM
Venting balconies
I had a new construction yesterday that has a vent strip... it seems to me that for proper venting two would be ideal (one foward, one back) to allow for some circular flow... Am I being over the top?! I assume the one strip will be fine, but wanted some other opinions.
THanks,
Reis
08-04-2008, 08:59 AM
Re: Venting balconies
Why would you vent a balcony?
08-04-2008, 09:21 AM
They vent them around here, but I only usually see the one strip at the bottom outside edge.
08-04-2008, 10:55 AM
assuming the top and bottom are completely enclosed, and you did want to vent them, simple logic would be that you would need a place for air to enter in order for air to escape. otherwise if you could get it to vent with only air exhausting, the space would then become a vacuum. theoretically.
08-04-2008, 02:05 PM
How can you tell if 1 vent is working or not?
How can you tell if 2 vents are working or not?
Best
Ron
08-04-2008, 05:18 PM
Any balcony that has a soffited (is that a word?) under structure is vented so that the excessive moisture does not get trapped, rotting out the frame/sheathing, etc. The top side of these decks is an epoxy membrane coating. The strip(s) are intended to move air over the joists so that moisture does not build up enough to damage the joists/sheathing.
08-04-2008, 07:17 PM
Yes you are correct but.
Best
Ron
08-04-2008, 07:24 PM
Best
Ron
Ron,
If it's open & not obstructed it's Functioning as intended.
Billy J. Stephens HI Service
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Venting gas furnace acceletaes deterioration of flue formerly venting oil furnace? |
Michael Thomas |
Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection |
21 |
06-28-2008 06:37 PM |
| Toilet venting |
Frank Bombardiere |
10 |
06-06-2008 09:46 AM |
| Appliance venting |
Richard Roshak |
8 |
05-05-2008 07:24 PM |
| drain venting |
Jerome W. Young |
Pool and Spa: Home Inspection and Commercial Inspection |
3 |
04-20-2008 06:06 PM |
| h2o venting |
cris donato |
4 |
01-10-2008 12:41 PM |
Ad Management by
RedTyger
