Old 08-23-2008, 10:22 AM
Bernie Caliendo Bernie Caliendo is offline
Pervious Concrete
I'm starting to see the installation of pervious concrete for driveways and sidewalks. I have not observed their conditions in the cold northeast yet. Does anyone have experience with observing it's use in freezing conditions? I would assume it will begin to freeze and plug up.
Old 08-23-2008, 02:38 PM
Re: Pervious Concrete
Also, I can imagine that cracking will be a problem too, as that stuff has to be weaker than 'ordinary concrete'.
Old 08-23-2008, 03:04 PM
Ted Menelly Ted Menelly is online now
Quote:
I believe that it has a better expansion and contraction and maybe that is why they are using it and or flexibility.
Ted Menelly
"Castle"
Home Inspection Services
Old 08-23-2008, 08:25 PM
David Banks David Banks is offline
Pervious, Porous Concrete Pavement Engineering Properties
Seems to have good strength and freeze/thaw applications.
Dave
Old 08-24-2008, 12:13 AM
Jim Luttrall Jim Luttrall is online now
Quote:
Note that the porosity of pervious concrete from the large voids is distinctly different from the microscopic air voids that provide protection to the paste in conventional concrete in a freeze-thaw environment. When the large open voids are saturated, complete freezing can cause severe damage in only a few cycles.
It would appear that it would depend on your weather. Heavy wetting with extreme cold could be very bad.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #6 (permalink)
Old 08-24-2008, 04:47 AM
Quote:
Jim. I believe they are talking about conventional concrete in your quote.
Dave
  #7 (permalink)
Old 08-24-2008, 03:25 PM
Quote:
Freeze-thaw resistance of pervious concrete in the field appears to depend on the saturation level of the voids in the concrete at the time of freezing.
This is the introductory sentence of the same section.
Still seems to say that saturation will damage the pervious concrete, but that pervious concrete does by design drain faster than conventional concrete. But with reference only to 10 years of historic data, I would still be looking heavily at the local weather.
Allen, Texas 75002
  #8 (permalink)
Old 08-24-2008, 07:19 PM
My personal opinion is that:
- concrete is very strong in compression
- concrete is very weak in tension
- ice is very strong in expansion forces
- (okay, so those are not "my personal opinions", they are standard opinions shared by most people, including the experts)
- in cold climates water left exposed to the cold freezes
- when water freezes it exerts tremendous expansion forces which can break concrete apart (because of its low tension strength)
- in cold climates, after moisture falls (be it rain or snow), water penetrates down into gaps and cracks
- that water freezes (see above for what happens when it freezes)
  #9 (permalink)
Old 08-25-2008, 05:16 AM
Jack Feldmann's Avatar
Jack Feldmann Jack Feldmann is offline
From the web site under FAQ's
Q: What about freeze-thaw issues?
A: Pervious concrete has been placed in freeze-thaw climates for over 15 years.
Successful applications of pervious concrete in freeze-thaw environments have
two common design features-- the cement paste is air-entrained, and the
pervious concrete is placed on 6–12 inches of drainable aggregate base (¾” or
larger clean gravel).
Similar Threads
Sweating Concrete Reis Pearson Sub-Structure: Home Inspection and Commercial Inspection 2 03-20-2008 10:43 AM
F4 crashing into concrete wall at 500 mph Jerry Peck General Chit Chat: Home Inspectors & Commercial Inspectors 3 12-20-2007 07:34 AM
Stones in poured concrete? Rick Maday Sub-Structure: Home Inspection and Commercial Inspection 2 12-11-2007 10:49 PM
concrete fan housing support John Arnold Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 12-09-2007 06:36 AM
Concrete block wayne soper Sub-Structure: Home Inspection and Commercial Inspection 17 04-15-2007 11:31 AM
vB.Sponsors
Ad Management by RedTyger
