Results 1 to 12 of 12
Thread: Direct vent and openable window
11-15-2008, 09:12 AM #1
New construction... Direct vent fireplace in a living room with an openable window directly above it. Is there any reason why this might be okay? I'm having a hard time believing that no one else caught this before an occupancy certificate was given.
11-15-2008, 10:30 AM #2
11-15-2008, 01:52 PM #3
Re: Direct vent and openable window
Reis,
What type of siding/panel system is that?
11-15-2008, 02:37 PM #4
11-15-2008, 11:47 PM #5
11-16-2008, 07:23 AM #6
11-16-2008, 03:20 PM #7
Reis,
That's not HardiePlank.
It might be HardiePanel, except that does not look like HardiePanel (surface texture) nor does that vertical joint treatment look like anything shown in the HardiePanel installation instructions ... thus I suspect it is not HardiePanel either.
11-17-2008, 07:13 AM #8
11-17-2008, 08:21 AM #9
Check the manufacturer's instructions carefully. It is surprising what has become acceptable under the new building codes. One example is attached. In the instance of a direct-vented fireplace producing less than 50,000 btu, it can be as close as 9 inches to an operable window. Not the healthiest thing, in my own opinion, but it is allowed by code. The code refers the code official to the manufacturer installation guide.
Randall Aldering GHI BAOM MSM
Housesmithe Inspection
www.housesmithe.com
11-25-2008, 04:29 PM #10
It's not a good idea but really how many people open a window in the winter while the heat is running.
09-28-2010, 08:01 PM #11
Mike, I'm installing an oil fired water heater that's 148,000 btu. Does this appliance then need 4' to an opening window or door? Thanks, Tim
09-29-2010, 06:38 AM #12
Tim,
Read post #2. and "always" read the manufactures requirements for they provide the answer you seek.
